i have finished putting the girdle on the let and realised where the girdle sits on the the last crank cap ie cap on the ie flywheel end there seems to be a very slight leak and the engine isnt even running yet.
im going to have to remove the sump, girdle, all the selaent and remove the cap and seal it with gm black sealent better to do it now than when engine is in the car
what i need to check is
1. having sealent on the cap is there an easy way of removing the cap as its going to be stuck as the sealent is probably also acting as an adhesive
2. will i have to put in a new crank seal
3. when reseating the cap i put sealent around the cap do i also need sealent where the cap ends meet with one another,ie lower and upper cap meet, dont want the sealent squeezing out into the shells
4. is the gm black sealent ok for the job as currently the sealent is blue
