sealing the end crank cap on an let
Page 2 of 2 FirstFirst 1 2
Results 26 to 28 of 28
Thread: sealing the end crank cap on an let
  1. #26
    Oct 2003
    england
    Re: sealing the end crank cap on an let
    Nev that's where I was getting the leak, my girdle goes back on and I used black rtv sealent previously,it was that strong i could not get the girdle of even used leverage with a crowbar had to heat it slightly and even then it wasnt easy
    Hayes manual for the vectra,uses same end cap, says to use the black vauxhall rtv sealent
    Sep 2009
    Bristol
    VX220 Turbo, 485 BHP.
    You can only do your best, if it does leak when you are using the engine its quite possible to extract it and re-attempt to seal it again from under the car. If the car is on a ramp, I reckon it would be 2 or 3 hours work.
    Everyones advice sounds good to me, I reckon it must be a bit of a weak point on the engine design, or maybe some end caps just fit better than others. God knows.
    Less than 300 BHP makes the baby Jesus cry, more than 450 makes him a happy passenger!
  4. #28
    Oct 2003
    england
    all done
