c20xe miss fire?
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 45
Thread: c20xe miss fire?
    Mar 2011
    birmingham
    corsa
    c20xe miss fire?
    Hello
    i have searched and searched but i cant seem to find the awnser
    i have a xe in a corsa with no fault codes showing but its running lumpy and has missfire when there is load on it but if i rev gently it seems to be better? Cuts out every now and then aswell i would say when warmed up its a bit better? I have done
    changed cts
    cleaned icv overnight in carb cleaner (made a difference but still didnt fix problem)
    Unplugged tps and it revs up plug back in and it drops so i would say that works?
    Unplug afm it cuts out so that works
    new plugs and leads a month ago (couldnt be broke already?)
    also changed relay to a new one (no difference)
    What else could it be?
    Any help much appreciated as im baffled
    Moderator Melv's Avatar
    Dec 2006
    KEITH, N.E. SCOTLAND
    1.8 Corsa Merit + ACT
    Re: c20xe miss fire?
    What injectors are you running?
    Have you removed the plugs and inspected them?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    sounds like an intermittent fuel pump as mine did the same till i changed it
    Mar 2011
    birmingham
    corsa
    Quote Originally Posted by Melv View Post
    yellows with a 3.0 bar fpr as i dont have a 2.5 one and no not yet mate tomorrows job that is
    Mar 2011
    birmingham
    corsa
    Quote Originally Posted by vectra640 View Post
    i changed pump because i thought the one in it was buggered but ive got two so mite put other one in and see what happens?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    i thought mine was just noisy till it died on me yesterday, brand new Sytec pump for up to 500bhp that just dies, thats going back for a refund
    Mar 2011
    birmingham
    corsa
    Any ideas?
    Jan 2012
    Does it smoke? I have the same problem on my xe, If I put my foot down from low rev's it misses and runs all lumpy.. Im suspecting new piston rings..
    Jan 2005
    Cumbria
    Cav GSi & Cav Turbo
    I'd try a different Air Flow Metre.
    Owns: Cavalier GSi & Cavalier Turbo
    Mar 2011
    birmingham
    corsa
    Quote Originally Posted by Tillson View Post
    na doesnt smoke and would rings make it missfire and lumpy thoe?
    Mar 2011
    birmingham
    corsa
    Quote Originally Posted by Cav Lad View Post
    i will weekend soonest i can get one
    Oct 2003
    Cirencester, Glos
    GTE 16v Turbo
    You also want creams and a 2.5bar FPR on an XE with motronic 2.5.
    Mar 2011
    birmingham
    corsa
    Quote Originally Posted by Davey j View Post
    ive got creams with 3.0fpr
    Mar 2011
    birmingham
    corsa
    Today i cleaned the dizzy all points and contacts no diiference checked compression 145-150 psi in all pots and plugs are black and sooty? Also when started in morning will start for say 10seconds then cutout but start straight back up?
    MIGClub Member garymanc's Avatar
    Dec 2007
    Mossley,Manchester
    1988 16v Opel Manta
    sounds like overfueling you need a 2.5bar FPR as allready suggested
    Oct 2003
    Cirencester, Glos
    GTE 16v Turbo
    Quote Originally Posted by reecegsi View Post
    Was reading original post where it said yellows.
    You want a 2.5bar one on there. It'll be over-fuelling.
    Mar 2011
    birmingham
    corsa
    Oh ok thanks
    Mar 2011
    birmingham
    corsa
    Ive changed the fpr jus waiting for battery to charge then im gonna start it and see what happens
    Mar 2011
    birmingham
    corsa
    Ok all back together and now wont start lol no petrol out the nipple on rail so guessing no petrol getting there how could i find the problem? It has got petrol in and pump powers?
    Dec 2002
    S Wales
    TB'd Nova, S2000
    Find the fuel pump relay and feed the thick red/blue on the plug wire with a + from teh battery - that will run the pump....
    Too many Vauxhalls, not enough fuel.
    Mar 2011
    birmingham
    corsa
    Ok thanks ill try that now :-)
    Aug 2010
    Amsterdam
    5-door Astra MK2 C20XE
    You need to connect the three wider contacts together, just bypassing towards the pump is no guarantee to bliss as there might still be a couple of parts not getting voltage. Hence the relay I made with indicators can be a helpful part to make sure all parts are getting voltage. Basically there are three thin contacts of which two are getting connected to ground through the ECU, and one is another live wire (red/blue thin wire...) the first one will switch the first relay contact feeding the injectors, MAF sensor and ICV, and applies voltage to the second relay coil, which is earthed through the ECU, this will give voltage to the pump....
    Looking at the wire colours anything red is live, anything brown is ground and anything black is switched live....
    Mar 2011
    birmingham
    corsa
    Got it to fire with foot to the floor then had to keep revving to keep it alive but still no pettie out rail after a couple mins of running? This car is really starting to **** me off now!
    Is it a case of look over everything time?
    Aug 2010
    Amsterdam
    Don't know if it's been mentioned, but fuel filter??
  26. #25
    Jan 2005
    Cumbria
    Cav GSi & Cav Turbo
    With you changing the fuel injector etc, make sure you've pushed the loom right down onto the injectors.
    All so, when you changed ICV, did you plug the switch back into the ICV?.
