Then while you're at it maybe you can take the return fuel line off and crank the fuel pump for a moment while holding the line above a bucket, just to see if the fuel is pushed through....
Maybe it's the fuel pressure regulator?? See what happens when it's running when you squeeze the return line.... (use two wooden sticks and a pair of pliers, something that can squeeze fairly hard. Or if it is a rubber hose fuel line then bend it and squeeze firmly....
Have try'd taking the fuel pump relay off, give it clean and plug it back in?
Owns: Cavalier GSi & Cavalier Turbo
Ive tryed at least 3 relays and they all click no difference its not getting pressure because it wont come out rail when pressed how could i solve that?
Chance is the fuel pressure regulator is screwed and just letting the fuel pass pack in to the return line without any form of pressure build up. Hence the thing I mentioned above to make the pressure build up yourself by squeezing the return line a little... Maybe you should try that with the valve on the rail opened to see if that makes the fuel squirt out there....
Never tried the test above, so no guarantee it's the right method.
For what I understood the system works like a garden hose (fuel feed line), if you hold your thumb (pressure regulator) on the end you can make the water squirt out pretty far out the opening (injector). If you were to punch a hole in the side of the hose (pressure meter valve) and don't hold your thumb on the end of the hose there would probably be no water coming out the side hole, whereas there would be if you build up pressure by holding your thumb on the end....
Shall i try that ignition on and squeeze rubber bit of left (as you look straight at engine) petrol hose? Shall i undo the actual housing of the valve on rail? or just get someone to push valve?
Thanks vinci for your help
Ive done what you said vinci and it just dribbles out of valve so fpr gone?
Have you not got another fpr to try?. just sold my old fpr and injectors as well.
Only a 3.0 one which the car run just lumpy switched to this now it wont bloody start lol always the way
Na its good pipes fine
no not xe one its a 16v one
yh was on when i first done conversion but disconnected ecu overnite and it was fine just runs rough
I had a similar problem on my xe corsa, turned out it was a vacuum leak. Maybe worth giving them a check just to be sure
If it just dribbles from the valve it sounds like there is no pressure build up. So either the feed line is blocked, the FPR is gone or the pump/filter isn't okay....
I read earlier in the thread nothing was coming out, so when it used to shoot out, did the engine also still run fine? Or were the revving problems also present when it used to shoot out??
Alright, then at this point get a new regulator and see what happens...
