2.2 vectra problems starting ECU or CIM ?
hi guys, am new here and would like to say hello to every body, i have a vectra c that refuses to start getting some codes
p1514 throttle control malfunction
p0500 vehicle speed signal range
mileage circuit range malfunction
invalid signals from p.a.s, airbag and c.i.m
wrong enviroment indentifier recivd,
speed sensor fault
obviously i cant drive the car at all, so cant take it anywhere to get it sorted,
is there nay1 local to west londo that has tech2 capabilites that would be willing to come and take a look at it , i have a 2nd hand ecu, which needs programming to the car, but i dotn have the mobi code, but knwo that this can be taken from the old unit , to soemone with the knowhow and correct eqiupment
