right got my f20 box and my let has a pot flywheel on which iam gonna keep for now thing is what clutch set up should i use? need to know as want to order one over the phone and need to know what i need cheers![]()
F20 clutch type mate, you'll need the friction plate to fit the box main shaft, A LET or XE cover will fit and so will the thrust bearing, just ask for the pot type flywheel type
ok so if i just say a kit for a f20 box with pot type flywheel that will be right cheers
yep there are only 2 types for a standard f20 clutch
nice one cheers
you need a late spec c20xe clutch, (astra gsi with TC) or a c20xe friction plate and an clet cover plate (stronger), im told auto vaux sell them seperately.
www.wix.com/vxlgsi/zxr-750-r
they dont tried them today gonna order a standard f20 clutch for the recessed flywheel
