Does this gearbox look useable?
Results 1 to 22 of 22
Thread: Does this gearbox look useable?
    Mar 2003
    loughborough
    Calibre
    Seeing as it looks like the gearbox is terminally ill in my mk2 cavalier sri. Dug this spare one out the garage today. Its been sat for years in the garage and I don't know any history of the box. Wondering if anyone who knows gearboxs could tell me if it looks useable or not.
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Does this gearbox look useable?
    doesn’t look bad at all from the pics, i would get some scotchbrite and remove the surface rust on the gear selector drums, but the teeth and what you can see of the synchros look fine
    SHoNkyOpELs.de
    Mar 2003
    loughborough
    Calibre
    there's a slight bit of pitting on the selector drums would that be ok to just clean up?
    Oct 2003
    Romsey
    Cavs, Monaro CV8
    pmsl. loving this.
    yeah! it looks alright from a couple of out of focus pics!
    it's not good advice fella.
    maybe a strip and clean, as it's out anyway, is the only way you can tell what condition it is in?
    that'll give you a chance to get right inside to see the faces of the syncros, the bits that actually wear that is! and peel the guards off the bearings to clean them out and view any crap in there.
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    why is it not good advice? i said it doesn’t look bad from the pics? and it does look very clean, with hardly any burrs on the synchros (which you can see all of without a strip down) that are near standard on 2nd hand boxes nowadays, obviously if it spins and sounds like a cement mixer look at the bearings more closely, but as you say, they have dirt seals?
    SHoNkyOpELs.de
    Oct 2003
    Romsey
    Cavs, Monaro CV8
    it doesnt look to bad from what can be seen without x-rays specs I suppose, but, whatever the condition of any teeth you can see, how can you tell if the the grooves on the syncros are alright? are they full of swarf? are they all worn out and going to be crunchy as hell?
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Quote Originally Posted by Pitstoppete View Post
    Did you consider that he doesn't know how to do this, otherwise he wouldn't have asked whether it looks alright?
    I'd just clean it down and stick it in, see how it goes. Doesn't look obviously ****ed.
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    personally i would be happy enough with just selecting the gears a couple of times to check if the splines were clear, if they were likely to be full of **** i would say the rest of the gear set would not look so clean either, really not masses more you would learn by stripping it down imo
    SHoNkyOpELs.de
    Sep 2009
    Isle of lewis
    Cavalier turbo, mk2 golf
    quick answer jon give it a wee clean, bang it in , will be better than the one you have in just now
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    SHoNkyOpELs.de
    Oct 2003
    Romsey
    Cavs, Monaro CV8
    wang it in then, hopefully it'll be fine
    Mar 2003
    loughborough
    Calibre
    Yeah I've never ventured inside a gearbox before, just wanted to know if on the face of it wether it was useable. I didn't know if the pitting on the gear selector drums would render the box scrap. Was no swarf or metalic bits in what oil was left in it. Was a circlip stuck to the swarf magnet though. The imput shaft turned easly by hand, wasn't silky smooth but figured that might be because of the lack of oil and with it standing for so long. Worth giving the gear cluster a quick clean in something then re-asembling?
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yeah, petrol or similar wouldn’t hurt
    SHoNkyOpELs.de
    Sep 2009
    Isle of lewis
    parifin or as lee said petrol mate yes no harm in giving it a going over
    Jun 2002
    Wrectum
    if you degrease and wash out thoroughly with a pint or two of petrol to get all the crap and swarf out, then put a few drops of oil on, it should turn smoothly.
    Mar 2003
    loughborough
    Calibre
    Right sounds like a plan, thanks for the advice.
    Oct 2003
    Romsey
    Cavs, Monaro CV8
    pic of the circlip?
    Mar 2003
    loughborough
    Calibre
    As requested
    Took the old box out the car today, there's a noticable amount of play up and down in the imput shaft. (Had a knocking noise comming from the gearbox once the car had been idleing for a while that would dissapear with the clutch depressed.) The friction plate springs had also been catching on the flywheel bolts. Do you I'm right in thinking it'l be down to the imput shaft moving, allowing the friction plate springs to hit the flywheel bolts?
    Oct 2003
    Romsey
    Cavs, Monaro CV8
    clip is most of an input shaft outer circlip, which sits behind the M7 torx bolt inside 5th gear etc.. this is the one you remove to withdraw the input shaft if you are changing the clutch the quick way. it might be an old one that's pinged into the end case. Slight concern where the other end of the clip is! that could be the cause of :-
    a noise that goes away when the clutch is down could well be the input shaft end bearing by the splines, almost certain if you have a fair amount of play. could be your drive plate is well thin too.
    Mar 2003
    loughborough
    Calibre
    The circlip is out the spare gearbox. I thought it might be the imput shaft circlip, will take the 5th gear cover off and see if I can find the other part. Is there supposed to be any play in the imput shaft at all? The drive plate was thin but I've seen much thinner with out any problems.
    Oct 2003
    Romsey
    Cavs, Monaro CV8
    input shaft play should be tiny.
    you should see the circlip, if it's there, in the centre of the gear with a multispline torx bolt behind it. tricky to spot.
    Mar 2003
    loughborough
    Calibre
    I think you were right with where the circlip came from. A larger circlip had been fitted to the torx bolt in the imput shaft. Didn't find the missing part of the circlip though.
