isuzu 1.7 td conversion
Results 1 to 2 of 2
Thread: isuzu 1.7 td conversion
    Mar 2008
    edinburgh
    corsa, astra h, nova let
    Im putting a 1.7 td from a cavy in my corsa b and need a bit help with the timing belt. iv looked at guides and some say use a T belt kit from a 1.5 for clearance at the mount, iv trial fitted the corsa mount and can't see a problem its close but not touching. Will this be ok?
    any help is appreciated.
    Nov 2008
    wilmslow
    c20let corsa, volvo 360
    Re: isuzu 1.7 td conversion
    it only when you put the 1.7td into a nova you have to use 1.5 stuff, but corsa just bolt mount on and stick it,
