im not sure if its the piston rings has any1 had this problem before??
dont want to pull it to bits yet until im sure. cheers
Stem sills can be a common problem on x20xev's? Is the engine high milliage? When does it smoke?
If its first start of the day from cold then yes, stem seals
Probably just as easy to grab another lump.
Lots of treatments available to help thicken the oil slightly. Worth a try.
its done 106 thousand??
