Righto guys,
I have finally broken the Cav! or it's bust itself...it's been basically a very good boy for about 45000 miles since we put it in, I rebuilt it all from all good stuff maybe 5 years ago now, it gives proper power, pulls hard and can do 40 mpg commuting.
It's still driveable though, if I get me trotter down hard!......please read on!
Cylinder 4 is asleep - or not doing a great deal at idle and off of load.
It started running strange a week ago and the stink of the exhaust and wobbly idle made me dive right in and get a new bosch O2 sensor, as it did what seems much the same as that before and a new O2 sensor sorted it. Fitted that and reset the ECU with the battery off, that changed it a bit I'm sure, but it felt better maybe for the ECU reset. Still weird idle though...
When it's cold/warm or hot it's idling really lumpy on 3 cylinders, so the second thing I did was use my IR thermometer on the manifold, and at idle with a few throttle blips we have like 200 deg C on 1/2 and 3, then 50-60 deg C on down-pipe primary no. 4. well weird.
There's no fault code light and on my commute its doing decent MPG, it just dont like idling/progression..
Go for a roar, get it hot, get out quick and check again with the IR thermometer and we have much the same temp on all manifold primaries, like 300+ deg C all the way across all 4. It goes like stink on load, revs right out and is really smooth, unless you slow right down to 1000-1500 ish and try to go slowly.
Now the obvious comment I'm sure I'll get is give it death everywhere! And I would If I could I can assure you! but that aint going to help...
So, seeing as cyl no.4 seems to be at fault I have wound into swapping out everything I have, to see If I could sort it -
Compression test was 200/220/235/215 cold, 230/220/210/225 hot. cant see anything mad there...
Plugs changed for both new then old GM ones then swapped about between the cylinders. no change. 4 is clean and a bit damp after idling. rest are normal.
HT lead swapped, no change. massive fat spark when lead is pulled off when running.
Coil pack swapped, no change. I was sure it'll be that. fail.
Cleaned ICV/AFM. ditto.
Buzzed out CTS. seems correct resistance. 1.5meg warm IIRC.
All injectors same resistance. listened to them all using a long screwdriver. all 4 have a proper click click click sound going on. swapped them round anyway and tried a spare one, no change.
Looked into all the wiring connectors at the injectors/ICV/CTS/IGN Amp/Cam sensor/Throttle pot/AFM etc etc, all good.
Swapped the ecu for another correct PT code one, no change there either.
New O2 sensor, like the old one is sooty, showing the unburnt cyl. 4 fuel I suspect.
Knowing it would do nothing I've just swapped the fuel rail/regulator assembly too, to no avail.
Also as it has had some/a quite loud tappet/s now and again that I haven't got round to changing for the new ones as yet (probably one I couldn't get apart a couple of years ago when I cleaned them) I had the lid off and checked the cam buckets/cams. Everything inside seems fine and clean as the proverbial. The tappets turn when the cam is off them, they are close to the cam lobes like the rest and dont seem to be flopping up and down which I thought could happen if a tappet had died internally..
I have another coil pack engine loom from the Calibra I broke (which needs a bit of tidying up and one repair to the broken IAT wiring that's pulled out of the plug) and I could try swapping that out too, as that seems to be the only thing I've not swapped as yet. Or I could swap the tappets for the new ones too.
It seems strange that I could commute to work tomorrow and max it out in forth again at the end of the speedo, but it wont idle on all 4 frigging cylinders.
So has anyone got any other ideas?
