hi guys. does the c25xe need the oil cooler or can you blank it off and not run 1? engine is in a mk3 astra by the way. cheers jp.
i would use it as they are installed by default and that would be for a reason!!!
you can put a pipe in to bypass the oil/water cooler but dont blank it off
Its not an oil cooler.
Its designed to get the oil up to temperature fast for longer engine life.
ok cheers guys.
