c20let - refitted turbo now it wont run properly
Page 3 of 3 FirstFirst 1 2 3
Results 51 to 61 of 61
Thread: c20let - refitted turbo now it wont run properly
  1. #51
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: c20let - refitted turbo now it wont run properly
    took me ages to get it started and when i he it just cut out
    wtf!
    Roll on LET power....
    Aug 2007
    brighton
    C20LET 5dr corsa
    changed cts, started up ran bit rich but got better. i left it to warm up an once it had it leaned out an was sputtering jerking etc
    re starts on the button though then 1min later its messing about
  4. #53
    Aug 2007
    brighton
    C20LET 5dr corsa
    right I've let it warm up until it ****s about and i unplugged the afm, it ran much better!
    so i take it its the meter or the wiring?
  5. #54
    Jul 2009
    Tyne & Wear
    Corsa SRI Z20LEH, B X14XE
    see if anyone in area will let you try there afm
  6. #55
    Aug 2007
    brighton
    C20LET 5dr corsa
    its been left a few days an now it won't start again, i re taped the loom but every plug is gettin power.
    gettin fuel to, would a cooked afm cause it not to start? maybe its just fouled the plugs up@
  7. #56
    Jan 2010
    Hemel Hempstead
    Vectra B C20let
    It will start without the maf as that is how I got my car home after a boost pipe fell off.
  8. #57
    Aug 2007
    brighton
    C20LET 5dr corsa
    ok i will clean the plugs
  9. #58
    Aug 2007
    brighton
    C20LET 5dr corsa
    took the loom off and re taped it all, wires were all fine and connections. check for volatge at the sensors thats all good!!
    it refuses to start now, its getting fuel but can't be sparking! tried another new set of plugs an no joy!
    could it be a ignition live wire?? crank sensor? im still waiting for my afm but cant work out why it wont start!!! need it running as its going up for sale.
  10. #59
    MIGClub Member Corsa_LET's Avatar
    Sep 2011
    Nottingham
    Astra z20let sleeper
    Fuel relay, hall sensor? Crank sensor & cam sensor are about the only things that will cause it not to start, should start without the afm. Have you done a compression test & checked the timing?
  11. #60
    Aug 2007
    brighton
    C20LET 5dr corsa
    na i haven't but going to check everything!
  12. #61
    Aug 2007
    brighton
    C20LET 5dr corsa
    anyone got an idea where the ignition live is ment to go from-to?? just want to check all the ignition has power.
