v6 throttle body?
Results 1 to 18 of 18
Thread: v6 throttle body?
    Jul 2002
    Cornwall
    cav cabrio xe + sri 140
    v6 throttle body?
    I'm disappointed with my v6 Vectra, the throttle response is so poor compared to my SRI 140. You put the foot down, then wait a while for anything to happen!
    Has anyone used an enlarged throttle body (64mm machined to 68mm) on their 2.5 V6, and if so, does it help cure the problem?
    Just wondering if they are worth the money
    Jul 2002
    Cornwall
    Re: v6 throttle body?
    Sooo...no one tried one of these then?
    Feb 2007
    Belfast Ireland
    cavalier sri 3.1 v6
    I have my one enlarged on the cav its some job. Def get it done. Guy from ebay done my one I had his number but changed phone. He delt outside ebay I think allin end up costing about 60 quid. Barging if ya ask me.
    Before
    After
    Jul 2002
    Cornwall
    Yeah, there's a guy on ebay doing it for around £80.
    Any noticeable difference to performance Deegte?
    Would be handy to know if it goes some way to improving throttle response on the V6...
    Nov 2008
    wales
    vectra v6 st
    dont expect much but with the v6 it's more a case of every little helps...
    you could also maybe look at a lightened and balanced flywheel which will help with throttle response and a good service is always a good place to start.
    the gearing on the vec v6 is quite long and can feel sluggish until she getts going! lol
    Jul 2002
    Cornwall
    Don't really want to spend a fortune so just looking at the cheaper mods which may make a difference. Just converted to lpg so spent enough for now! :-)
    Nov 2008
    wales
    vectra v6 st
    yeah i no what you mean! lol
    how do you find the lpg?...been looking at it myself but not sure how it will fit in with future plans
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Flywheel is the issue here not the TB. The rotating mass of the engine is probably twice that of a X20XEV, hence the throttle response being poor
    Long ratio box as well dont forget.
    MIGClub Member elongmoss's Avatar
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    I do 68mm versions or 70mm enlargements for £50 usually with a weeks turn around
    The 70mm require the coolant at the bottom to be diverted however but is better for
    WOT type driving the 68mm is better for day to day use
    If at first you dont succeed... CHEAT!
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    how much to enlarge the twin butterfly omega one
    Jul 2002
    Cornwall
    Quote Originally Posted by 34ada View Post
    To be honest, I've been fitting the lpg kit over the past few weeks and am only now at the point where it's ready to stick the gas in and see how it works. Hope to be doing this sometime next weekend. I've spend about £800 on parts, but should recoup this within a year or two hopefully. It's a tricky business though on the V6, really difficult to find space for everything and many hours spent making brackets etc. Will let you know how it performs once it's done :-)
    Jul 2002
    Cornwall
    Quote Originally Posted by elongmoss View Post
    And in your experience, what difference will they make to the V6?
    Jul 2002
    Cornwall
    Quote Originally Posted by Nemesis View Post
    I wonder why they used the same box throughout the V6 range instead of using a close ratio on the SRI/GSI
    The smaller engined SRI's had the close ration box after all...
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Because a CR box wastes what the v6 is very good at and makes it really bad on fuel when you use it on the motorway. The F25 is too wide though.
    Nemesis is right though, your problem isnt the TB.
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    It's the near on 15kg flywheel and the long legged F23/25 box that's why I changed all of mine over when I rebuilt it, including the intake
    Jul 2002
    Cornwall
    Quote Originally Posted by vectra640 View Post
    What did you change over to?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Mine has a F28 which I know is heavier than the others but has closer ratios than the F23/25 and the extra gear makes up for the weight, mine also runs 3.0 omega plenum, quad G cams and a straight through 3.5 inch stainless exhaust, lowered over 60mm, bilsteins all round, front mount oil cooler, air con removed blahdy blah
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    I used an F20 with a F18wr 5th in it. I actually prefer it to an F28
