Novastien (just how does this car actually run)
Results 1 to 13 of 13
Thread: Novastien (just how does this car actually run)
    Nov 2011
    Ilkestonsestashire
    Mary Shelly's Nova
    Can anybody shed some light on my errr mostly nova 1.4 ohc I think, It has become clear that when I bought my nova it was actually made from a number of other car's, the list includes vectra,astra,cavalier,corsa b,corsa c and theres even some nova bits on it (lol), my problem today is (I believe) the ignition module, as it has just started cutting out for no real reason and now wont tickover unless at 3000rpm, after a bit of searching it would seem to have a 1.3 distributor on it (large black type with two wires coming out delco remey?). Can any body tell me is this even supposed to be on a 1.4 ohc engine?, as a new one that matches my engine number is clearly orange and has no wires.. Im confused
    May 2004
    Nottingham
    Re: Novastien (just how does this car actually run)
    Id imagine it's a carb fault, rather than dizzy, if it ran ok in the past?, it probably just needs a tune up, but I have a Bosch dizzy for it, if needed.
    Nov 2011
    Ilkestonsestashire
    Mary Shelly's Nova
    Cheers for the response, it has a pierburg 2e3 on and although it's somewhat of a incomplete unit it is set up well and has been running very well, economical and responsive on the peddle, the problem occurred last night whilst stuck in traffic, It just died.. It started again and tick'd over slow and lumpy, I eventually had to stop and raise the tickover to around 3000rpm just to keep it running at traffic lights ect, and this is exactly how the car is now after spending most of the day tinkering, I noticed a ignition module on the distributor today also and after having a few xr3i's in my time I know these can be pigs, should it even have one at all ?
    West Midlands Regional Coordinator paddy>gsi/turbo's Avatar
    Nov 2004
    birmingham
    astra mk3
    sounds like your sucking dirt up from tank. fuel filter fitted? if not fit a inline filter.
    Nov 2011
    Ilkestonsestashire
    Mary Shelly's Nova
    Yes a in-line fuel filter is fitted and the tank is in good shape inside and out. I have tried bypassing the tank altogether and feeding the carb direct from a squeeze bottle and its still the same, iv changed the plugs, leads, coil and carb none of these changes made any difference at all. This leads me to the distributor, when taking it apart i noticed that the ignition module looks brand new. Could running a 1.3 distributor on a 1.4 coil kill the ignition module?? could this be the reason it died in the first place ?
    Nov 2011
    Ilkestonsestashire
    Mary Shelly's Nova
    WELL !!!!!!!
    Jun 2003
    clacton on sea
    corsa c,125 dragster
    sound like ya idle jet is blocked mate, had it loads of times, strip the carb and give it a good clean !
    click here 2 c my old nova
    new WIP nova c16xe will get pics up soon
    Nov 2004
    birmingham
    astra mk3
    Well!
    By sounds of it you have a 1.3 engine.clean your carb fit new filter.
    Nov 2011
    Ilkestonsestashire
    Mary Shelly's Nova
    Engine code is 14nv
    Quote Originally Posted by paddy>gsi/turbo View Post
    Well!
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    As said, idle jet blocking is very common. Leads to uneven running and stalling. Give all the jets a good old squirt of carb cleaner.
    They're there, in their room.
    Nov 2011
    Ilkestonsestashire
    Mary Shelly's Nova
    Quote Originally Posted by mk2novakid View Post
    tried another carb (not the same type) didn't work tried cleaning three times with various results(none good) bought another distributor (the correct one for the engine) better but still lumpy, just bought another pierburg 2e carb, carb to manifold gasket and a inlet manifold gasket, I'll fit it tomorrow so hopefully fingers crossed it will work. if not the car's for sale! there's not allot left on the fitted carb so a complete unit would be better.
    Nov 2011
    Ilkestonsestashire
    Mary Shelly's Nova
    New carb and gaskets fitted... all seems well!
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Could also have been a small biece of crap holding the float needle valve slightly open, causing it to run rich (mild flooding) until the fuel demand could use the excess fuel supplied.
