finally got my 20seh running today on r1 carbs and megajolt
all running fine untill the alternator belt came off for some reason
i put it back on and it came off again this time getting stuck behind the lower timing belt pulley i ended up cutting the old alternator belt off as it was all twisted by now
before i fitted the new one i checked the timing, it was bang on when the engine was put in
i put piston 1 to tdc and the cam shaft is now sitting here
a good few teeth out, the engine still turns over by hand find and can still hear compression while turning it by hand
something isnt sitting right though to make the alternator belt come off, ive took a few pictures of how i have things set up
bottom timing belt pulley, as you can see its not sitting right
water pump
cam pulley
the way i have the bottom pulley set up is i put the big washer on first, then the woodruff key, then the pulley them the main bolt and thick washer
is that correct?
