c14nz cutting out
Results 1 to 20 of 20
Thread: c14nz cutting out
    Dec 2011
    c14nz cutting out
    Garage says the cam sensor inside the dizzy is cutting the car out does anyone know where to get one or have one ?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Re: c14nz cutting out
    I have a coil pack type as I stripped the 16nz engine in mine and have all the parts, I take it it wasn't the pump?
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Give me the part number and I'll check it with mine
    Dec 2011
    Sorry mate not sure of the part number i think its a hall effect sensor, and the pump has made it run better will have a better description when i pick it up today
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Quote Originally Posted by jamieboy View Post
    Ok mate, I have the entire coil pack which i know was working perfectly, just need to check the numbers to make sure it fits, but I'm sure they are the same
    Dec 2011
    Mines has a dizzy mate not a coil pack
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Ok, I dont have one of those sorry, start a thread in the wanted items and someone will have one
    Dec 2011
    Thanks anyway bud, will do
    MIGWeb Moderator
    Midlands
    Nowt
    Yeh, Vectra640 he needs the hall effect sensor thats part of the dizzy.
    Nothing to do with the coil.
    No local scrap yards near you?
    You just need to swapy the dizzy over. You dont say where you live, so cannot offer any more help.
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    No mines the coil pack type Paul, not a mechanical dizzy, that's what I meant, I have the whole unit for the 16nz not the 14nz which is what he wants, don't know if they are the same though, but in saying that his 14nz shares the same ECU as the 16nz so his must be a coil pack
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Post a pic up of your dizzy mate and I'll let you know if it's the same as mine
    Dec 2011
    Yeah need to swap over the whole dizzy as you cant get the sensor seperate, stay in Greenock Scotland mate not a scrappy around here has one
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    post a pic of it up here and ill see if its the same as my one
    Dec 2011
    copied this from another site but it is the exact same as this one
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    Nothing like mine at all mate mines like this:
    Dec 2004
    Heathfield, BEOB
    Things With Engines
    They are available on Ebay mate just found some for you.
    Click on the links below:
    Vauxhall Astra distributor POWERSPARK
    Vauxhall Distributor Corsa Nova Astra 0237 521 024 | eBay
    Astra Cavalier 1.6SV Bosch Distributor, New! | eBay
    Opel Astra distributor POWERSPARK
    one of these should fit
    Check part numbers before buying, you will have to take off your one and cross check the number on yours
    Dec 2011
    Excellent mate cheaper than some used one appreciate the help bud
    Dec 2011
    More problems went to try start the car tonight and no go!!!!!!! Decided to check the voltage to the fuel pump and gave a reading of 7 - 8 volts, left if for five mins and checked again and got a reading of 2.5 - 3.5 volts, checked the battery voltage and it is reading 12 volts then my torch died so cant check anything else. Any ideas?
    Oct 2005
    Sandycroft
    mk3 astra 1.4 vectra 2.2
    Did you sort this problem out? As my Astra stalls and refuses to start sometimes
    Dec 2011
    Got it sorted mate i just ran another wire from the earth cable and attached it to the body under the back seats and not had a problem since hope this helps
