C20LET injectors upgrade
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: C20LET injectors upgrade
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    I need to upgrade my injectors cause i think are close to the maximum they can provide
    Actually i'm running the classic Bosch 0280 156 280
    470ccm @ 3.0bar & 575ccm @ 4.5bar
    High Impedance 14.2 Ohms
    But i don't would like to run over 3.5/3.8 bar (or i'm wrong?)
    Anyway my fuel pressure regulator can give since 4.7 bar and i have a Sytec fuel pump 255 l/h
    The purpose would be a setup ready for 400/420 HP no more
    I was thinking about these injectors
    Siemens DEKA 630cc
    low 630cc/ml/min @ 3bar
    - 4 hole orifice
    - Length: 75mm long version
    - Cone type spray pattern, angle 26 degrees
    - 12 ohm, high impedance
    - Opening time 1.3ms / closing time 0.7ms
    - Connector: Old style Junior Timer (AMP/TYCO)
    Siemens DEKA 840cc
    Flow 840cc/ml/min @ 3bar
    - 1 hole orifice
    - Narrow cone type spray pattern, angle 10-15 degrees
    Siemens / Mototron DEKA IV
    Static Flow Rate: 80lb/hr = 875 cc/min
    Dynamic Flow Rate : 18.6 mg/pulse 2.5ms PW, 20 ms Period
    Coil Resistance: 12 Ohms
    Connector: Bosch EV1
    Series: DEKA 4 ( DEKA IV )
    O-Ring Type: Viton
    I think all are the standard bosch type injectors 60mm O-ring to O-ring
    The price is about 160/180 GBP for a full set of four
    Second question: i can drive these injector by the Motronic M2.7 engine management (obviously remapped)?
    Astra MK3 C20LET Work in Progress
    MIGClub Member cmac86's Avatar
    Mar 2006
    Invercyde
    MK3LET/Vec C/VFR750
    Re: C20LET injectors upgrade
    I think the Deka 630cc's are good for about the 500bhp mark @ 3bar
    I'm also running the 470cc's with a GT28 and they are maxed out at just over 330bhp on the Motronic. I'll be upgrading to the 630's when I eventually want more power. Not too sure how the 630's will run with chips though. I'll be going stand alone in the future I think.
    Wanted: 15" Pro Race 1.2's!
    Total Vauxhall Cover Car - Issue 129
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    Yes i suppose my injectror fuel since the same amount of power
    MIGClub Member c20letian's Avatar
    Jul 2009
    Kent
    Calibra 4x4
    isnt bigger better? 840cc all the way and then turn down the fuel pressure..
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    Quote Originally Posted by c20letian View Post
    Not on standard management no cause you get a crap idle
    And I'd say 660's will be perfect For what you want
    Jul 2009
    Kent
    Calibra 4x4
    personally i don't care about idle. but when i finish my car i wont drive it that much.
    May 2001
    South Wales
    Nippy Cav Turbo
    I was running MSD 550cc's injectors @ 3.0bar fuel on a gt3071r at 1.65bar of boost at approx 400bhp on Vmax Evo5 chips all fine here
    May 2001
    South Wales
    Nippy Cav Turbo
    I bought and tried 660cc's Siemens Dakar injectors and the car wudnt even run right...i.e. wudnt start and hold idle lol so sold them and wacked in MSD 550cc injectors and all was gravy.
    Jul 2009
    Kent
    Calibra 4x4
    this is good ****... my old friend that has a 512bhp GT4 once told me that... sillycars are made different?
    May 2001
    South Wales
    Nippy Cav Turbo
    matter of speach? lol
    Mar 2006
    Invercyde
    MK3LET/Vec C/VFR750
    Quote Originally Posted by Adam View Post
    Did you change the MAP sensor or was it factory? Might be worth me upgrading my injectors to see if I can squeeze more power on the Phase chips. I'm running Evo 5 and the VXR's are 100% duty at 1.2 bar of boost.
    May 2001
    South Wales
    Nippy Cav Turbo
    Dont need to change map sensor on Vmax Evo5 software...but I will be doing with my new software @ 3bar map sensor. I was running vxr injectors before but went for the msd 550cc's then.
    Mar 2006
    Invercyde
    MK3LET/Vec C/VFR750
    Sweet, cheers. Did you upgrade to the 550's because you maxxed the VXR's?
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    This is a great result for 550 injector
    According to some injector calculation i supposed that at 3 bar would need a minimum of 630 cc/min injectors ... better go to about 800... but i'm not an expert about that
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    I was quite sure that M2.7 could not andle boost over 1.2 bar with its standard MAP sensor.
    I read also something about an "internal" limit of a 0.9 loop but not sure of the meaning
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    That's up to you but if a car can't idle its more likely to stall etc
    What's the car used for? As if it's his every day car I'm pretty sure he wants it to idle properly, you can get away with the 550lb (525cc) MSD injectors on the later chip sets i.e evo 5, phase 3.5 & 4 but for 400bhp the duration on the injectors are running near there max so 670's would be my choice but only if your on aftermarket
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    Whats the motronic limit for bigger injectors than 550?
    May 2002
    Rainham, Kent, UK
    FWD LSD C20LET Calibra
    Remember you have to get the car through the UK MoT if you want to drive it on the road (unless its a track day car), any more than 1000rpm and its fail (this is the trouble I had). Increasing fuel pressure/rate will likely make your engine idle high.
    www.topbuzz.co.uk : FWD LSD C20LET Calibra
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    I use my Astra only for track day use
    no MOT, no public streets.
    May 2001
    South Wales
    Nippy Cav Turbo
    Quote Originally Posted by cmac86 View Post
    I was running the vmax evo5 on the vxr's for quite awhile but as I was raising boost finding its limits I came across sum 550cc's and felt the more leeway the better so in words to that effect yeah matey
    Quote Originally Posted by avantrax View Post
    You might be right but I am just going on what my afr wideband was telling me that all was ok on boost with the injector flow.
    I tried siemens 660cc's and the car wudnt idle lol though it cud of been a funked amal valve at the time because I did have problems with that but got pissed off took them out and wacked the 550cc's back in and ran fine...so maybe it wasnt the amal valve...phuck knows bloody c20lets..enuff said!
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    Other ?
    Sep 2004
    Greece
    tigra/LET westfield
    siemens 630 here at 3bar,they do good so far.
    MIG.....Made In Greece LOL
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    As said, the problem with big injectors is accurately mapping the fuel for low flow conditions (idle). Dropping the fuel pressure may not help, either, as insufficient pressure may compromise the spray pattern.
    IIRC, some injector brands/designs are better for this than others.
    This problem is the main reason for using two injectors per cylinder for high power engines that also need good idle and emissions control. low fuel demend can be met by one and when higher fuelling is required, the second can suppliment it.
    May 2008
    Jablonec, CZ
    Astra_F-2.0T-Vems
    I have Deka 630cc for sale right now (they are already small for my target, I've made 360PS@E85 with them - see my project page). PM me if you have an interest...
  26. #25
    Apr 2008
    Italy
    Astra GSI MK3 GT28
    Quote Originally Posted by Gordo View Post
    Ok thanks for the info :-)
