Simplifying an X20XEV engine, advice welcome
Results 1 to 21 of 21
Thread: Simplifying an X20XEV engine, advice welcome
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Hi guys
    Right I've got an X20XEV engine and I want to remove as much of the EGR type stuff as possible
    First off what are items 1 and 2 in this pic? EGR and something else?
    Can I remove them by fitting the plate underneath (3) from an early X20XEV that doesn't have 1 and 2?
    Secondly whats the black box in the breather pipe? Any benefits to removing?
    May 2006
    Redditch
    Re: Simplifying an X20XEV engine, advice welcome
    I can't remember what 1 was as It's been a couple of years since I looked into this but if you remove 2 and you're using the standard ECU, it'll still need to be plugged in as it'll throw on the EML.
    MIGClub Member innovation's Avatar
    Sep 2007
    Yorkshire
    Isn't number 1 part of the 'secondary air injection' system?
    Design to Eclipse - Yorkshire website design
    Apr 2005
    Derby
    Way too Fast :-/
    As above part 1 is part of the SAI and connects to the big fan (summat to do with warming the lambda up), part 2 is the EGR valve, The big black box is the fire trap or oil condenser or summat, It was a mod. Think part 3 is a manifold type block, early ones are the same shape but dont have mounting holes in them.
    If you look under the exhaust shield there is another pipe connects to the Exhaust mani aswell.
    Sep 2004
    Nottingham M1 J26
    Cheers lads, so shall I disconnect 1 and 2, but leave the wiring plugs plugged in?
    And then get an early #3 to blank it all off?
    Apr 2005
    Derby
    Way too Fast :-/
    Thats what i'm looking at doing, or blanking the egr and leaving the rest redundant. If you do it as suggested you will need to do something with the pipe that runs across top of exhaust manifold, think you can just cut it off and weld the ends, seen all sorts done tbh.
    Sep 2004
    Nottingham M1 J26
    Quote Originally Posted by gixerboyuk View Post
    I've got a lexmaul manifold to go on
    Apr 2005
    Derby
    Way too Fast :-/
    Nice one
    Sep 2004
    Nottingham M1 J26
    Fancy a trip to looms then mofo?
    Apr 2005
    Derby
    Way too Fast :-/
    Must be due for one. When ya thinking of going?
    Sep 2004
    Nottingham M1 J26
    Anytime really, im free most days!
    Northeast Kent
    yeah part 1 lets air into the exhaust manifold during cold starts, creates secondary combustion in the exhaust heating the cat up quicker
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    I believe so. Fairly certain the same part fits from the C18XE which has the casting for the EGR but no holes for it. I've heard mention of using the same from a Z20LET but don't know if it's a straight swap.
    Apr 2005
    Derby
    Way too Fast :-/
    Quote Originally Posted by Nemesis View Post
    Could be free sat morn, Is the cob van still going? Lol
    Sep 2004
    Nottingham M1 J26
    Yeah not got alot on on Saturday... and yes kaye is still there. I bet she'd give a cracking handjob with that pie arm and a bit of bacon grease
    Sep 2004
    Nottingham M1 J26
    Z20LET one is looking promising guys
    Gonna clean it up and try fitting it later
    Sep 2004
    Nottingham M1 J26
    Yep it works
    Z20LET doesn't appear to have a sender in this part for the temperature gauge, so it's blanked off. I rounded one trying to get it out, the 2nd plate I tried I had to WD40 repeatedly then heat up before hitting a 1/4" imperial socket onto it which bit hard enough to remove it
    Standard Calibra/Cavalier sender then fitted
    Sep 2004
    Nottingham M1 J26
    Whats the crack with leaving something plugged in to stop the ECU missing the EGR valve? Do I need to leave the whole valve connected or can I put a resistor over the plug terminals?
    MIGClub Member elongmoss's Avatar
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    yep you can use a resistor as the EGR is only a coil to open and close measure the resistance and find a sutible resistor pref about the 1 watt version as smaller ones may burn out
    or on some ECUs you can disable the EGR with tech 2 saving the hassel
    Oh and what you plan on bringing to the pod in march???
    If at first you dont succeed... CHEAT!
    Sep 2004
    Nottingham M1 J26
    Quote Originally Posted by elongmoss View Post
    That's classified information Gaz, on a need-to-know basis.
    You don't need to know
    Scottish Regional Co-ordinator
    Sep 2004
    Fife
    Cav T, SRi, V70 TD & 850R
    I've done all this on mine... removed pretty much everything though the EGR valve is still in place however is blanked off (Coke can FTW!) and I've also binned all the secondary air injection and cut the metal pipe from the manifold, clamped and sealed the ends. It's fine, idles fine but on idle it's making a constant squeak that goes away if I open the throttle flap. So, basically when there's vacuum in the inlet - constant squeak, when there's positive pressure in the inlet = no squeak. So, I can only assume it's drawing air somwhere down the side of the ehad or around the inlet manifold. Can I find out where? Can I feck!
    At this rate, Saab power could be the easiest option!
    Cavalier Turbo Owners Club - As long as it runs I really dont care...
