tc throttle body
Results 1 to 3 of 3
Thread: tc throttle body
    Aug 2010
    llandudno United Kingdom
    Astra mk3 gls gsi
    tc throttle body
    I got told the other day that the tc throttle body is ristrictive just want to no if that is true??? all so if i put solid lifters in on standerd cams would i get any gains on a c20xe???
    Northeast Kent
    Re: tc throttle body
    TC throttle is same size as normal one, i imagine its invisible to airflow when cranked open
    solid lifters on standard cams, yes you will gain some clattering from the valve train
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Solids on a hydraulic cam? You'd need a damned good reason for that as there are a bunch of disadvantages, such as
    Noise
    Having to set the clearances
    Reduced lift and duration because of the clearances
    Reduced life due to the lack of clearance/take up ramps
    etc
    Much better in every way to use the hydraulic lifters they were designed to work with.
Tags for this Thread
