C20LET Mk3 Astra Lsd... before and after
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 27
Thread: C20LET Mk3 Astra Lsd... before and after
    Oct 2009
    wolverhampton
    Astra Gsi
    Hi. Running a LET in a mk3 astra. Always wondered how much difference it actuli makes. I Spose id like to know if ur capable of doing a lot more, other than it feeling better. Can u approuch exit faster? It's an f20 I have in mine. Recently upgraded to 5stud with 16's. It's actuli quite well handled. Although ideally I'd like around 280horses, which brings me back to the question. What is it like?
    Cheers.
    Aug 2010
    Amsterdam
    5-door Astra MK2 C20XE
    Re: Lsd... before and after
    The harder you rock it the better it feels and the more difference it makes, been riding a Lotus with lsd on the track after it was just fitted and been driving it lots of times before without. Was amazed by how much further I could actually take it still feeling secure.
    But that's a different car...
    Dec 2007
    Nuneaton
    A carbed xe'd reno kangoo
    yes you can exit faster as when you take the corner usually as you are leaving the corner / island you would wait until your straight ish before planting your foot because it would just spin up but as it does the lsd transfers the power away from the spinning wheel over to the opposite so you get maximum pull and no spin up thus faster out of the corner.
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    May 2002
    Rainham, Kent, UK
    FWD LSD C20LET Calibra
    I've had a LSD fitted in my FWD F28 for some years on my C20LET engine (still running 200bhp as standard). Trouble is I don't know if it has made any difference because I don't know anyone with FWD F28 C20LET car to try. Put it this way - I've had no trouble with it, having better quality tires helps
    www.topbuzz.co.uk : FWD LSD C20LET Calibra
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Even on a standard Cav Turbo with FWD you'll be spinning up wheels on coming out of tight bends and roundabouts with open diff
    Dec 2007
    Nuneaton
    my gte was crap in the wet, I got done by a 125 put put up a hill because no matter how softly I accelerated as soon as I got boost it would just spin straight up lol
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    Northeast Kent
    the biggest sensation is a "self steering" effect. say you are taking a fast right hand corner with firm grip on the wheel. when the unladen drivers side wheel loses traction it applies torque to the passenger side (yeah we knew that bit) but because the passenger wheel is on the outside of the turn it pulls the nose of the car tighter into the apex.
    its a scary sensation at first, but you retrain your brain quickly.
    the downside of it, as joker said, you will get many times when there is too much torque even when two wheels are being equally driven. in the rain on corners it will turn safe wheelspin of the inside unladen wheel (on an standard open diff) to power understeer (with an lsd). some restrain needed in those situations but will still outperform an open diff.
    Jun 2002
    Wrectum
    Bare in mind you're not talking about an LSD there, you're talking about an ATB
    Northeast Kent
    its mig, there is only one lsd lol
    Jun 2002
    Wrectum
    lmao
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Whew, thought blotting paper or suger cubes might have been under discussion...
    Jun 2002
    Wrectum
    pmsl
    Oct 2009
    wolverhampton
    Astra Gsi
    This is what sounds gd. There's a lot of scoobys and 4x's runnin big brake round my area. I can stick with em, even on the islands and bends, but i feel at disadvantage! I obviously can't go all out as they do. I imagined havin and LSD to do what you said. Cheers bud
    Mar 2009
    essex
    astra gsi mk3
    its like nite and day, but as said if its wet, u'll loose traction on both wheels and end up with no steering rather than just spinning the inside wheel, in the dry thou the harder u drive the more traction u have, in my standard 150bhp gsi, i was out paceing a mk4 gsi (200bhp) around castle combe, just because with my quaife my entry, mid corner, and exit speed was miles faster
    best mod ever pound for pound, period
    Oct 2009
    wolverhampton
    Astra Gsi
    Is it the quife diff u got? Theres a transX, and another called Kaaz I think it is. Think its a must, as for wet days.. I don't bother takin the motor out tbh. I have a diesel day to day.
    Rite, time to save!
    Mar 2009
    essex
    astra gsi mk3
    mine is a quaife. As i understand it is better for road cars as u can still park without the lsd tryin to do somethin stupid.
    It's a big learing curve when you first start driving with one. I know that.
    Dec 2006
    South Africa
    Opel Corsa B c20let
    The trans-x plated lsd is better for track days and everyday driving as it only engages when a certain torque is reached.
    Quaiffe is better for 1/4mile, driving everyday is difficult as the lsd is working all the time.
    1997 Corsa Lite 2l16v TS Standard 1/4 mile 13.285s @ 167.7 km/h
    2007 Nissan 1400 Champ 20LET (Conversion in Progress )
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Best mod I have done. accelerate much sooner out of a corner on track and actually get pulled in as opposed to out.
    On the road takes some adjusting though, especially accelerating out of roundabouts, You learn to hold the steering wheel a bit tighter for sure.
    Mar 2009
    essex
    astra gsi mk3
    mines a quaife too
    May 2002
    Rainham, Kent, UK
    Quote Originally Posted by 8valve-craig View Post
    I must be missing something here or my quaife ATB in my F28 isn't set up right (I've had it for about 8yrs now). I haven't had to get used to anything - just drive normally. Though I do have ultra cheap tyres (18" for £50 a corner
    Mar 2009
    essex
    astra gsi mk3
    you can only feel it in the dry on tyres that cost more than a nite down the pub!
    Oct 2009
    wolverhampton
    Astra Gsi
    Guess what iv got
    MIGClub Member Corsa_LET's Avatar
    Sep 2011
    Nottingham
    Astra z20let sleeper
    Chlamydia
  26. #25
    Aug 2010
    Amsterdam
    I was going to say PICS!! But was stuck in a deadly laugh over the above.....
