quick and maybe silly question but here goes...if the driveshaft has been removed from the transmission then put back in would it affect the gear change?
also does anyone know how much gear oil the 2.2 dti takes?
only reason the shaft had to be removed is because the outer cv joint refused to seperate from the inner cv if you get me
cheers
