C20xe getting HOT
Results 1 to 11 of 11
Thread: C20xe getting HOT
    Feb 2005
    Durham, Durham, United K
    corsa 1.3 twin 40's
    C20xe getting HOT
    My maye has done a conversion into his corsa b but the rocker cover gets red hot after 5 mins on tickover, it is very temperamental starting, sometimes it's first turn, other times it's got nothing there, any ideas lads? Cheers andyÂ*
    Wob
    Wob is offline
    Jun 2011
    bromley, kent
    Re: C20xe getting HOT
    how hot are we talking? my c20xe gets hot too.. i can put my palm on my rocker cover it for like 3 seconds max before flinching...i think the tempermental starting could be a seperate problem to the fact that its just hot
    MIGClub Member Turbostevo's Avatar
    Jan 2011
    Chesterfield, derbyshire
    Saabastra/E36328/bora/147
    It's very rare for any engine to get hot on tickover chaps, especially so hot that you can't touch the rocker cover after 5 mins. Starting problem could be an immobiliser, could be your using the wrong key? is the battery connected? Does it have a starter motor? Good luck with the trouble shooting lads
    Jun 2011
    Herts
    Corsa Redtop
    dizzy or coil ?
    when u say nothing there, does it sound like it wants to start but isnt, check if there is spark. once its going does it stay working or does it cut out?
    Feb 2005
    corsa 1.3 twin 40's
    Quote Originally Posted by Jayy View Post
    dizzy or coil ?
    Theres nothing there at all mate. We have replaced the dizzy, plugs and leads and it's still been dodgy! Once it is away it's fine then the rocker cover is too hot to touch After a few mins. Far too hot for it to be normal I think??
    Jun 2011
    Herts
    Corsa Redtop
    i know mine gets hot aswell but i just fort that was redtops altogether tbh.
    Mar 2005
    consett/durham
    bmw 320, corsa 2.0,
    Am having the same problem with mine. Had a problem with fuel pump so wired it in to a switch. Sorted the fuel problem but now runs hot then dies and won't start, Pulling my hair out now lol
    Jun 2011
    Herts
    Corsa Redtop
    is there any eml coming up dj ?
    Dec 2007
    Nuneaton
    A carbed xe'd reno kangoo
    Sounds like possible timing issue? Have you checked the markers are all correct, If its taking ages to fire I would take a look at the timing first.
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    Mar 2005
    consett/durham
    bmw 320, corsa 2.0,
    No eml, al check timing some time this week n let u know the result gonna change cps as well.
    I am here: http://tapatalk.com/map.php?ghxvnk
    Mar 2005
    consett/durham
    bmw 320, corsa 2.0,
    Check timing was out by a tooth, sorted now, still won't fire up got a good spark, fuel to fuel rail yet not firing up. Plugs look dry still after turnin over n over? Could there be another issue ie fuel relay or blocked injectors? Is there a relay or fuse for anything involved with the startin sequence? Help pleeeeeeaaassssseeeee
    I am here: http://tapatalk.com/map.php?axafno
