whats this flange? t34?
hi guys hope u can help me im treying to find out what flange this is i.e what turbo it would join to? possibly a t34 maybe? any suggestion
thanks adam
ive been told this is astrasi old astra coupe if that helps and scott@cdg
Re: whats this flange? t34?
any ideas i cant find anything
the .48 exhaust housing found on t3s and t34s has a similar sort of thing but has 3 bolts instead of 4, sorry don't know any more than that lmao.
Chop it off and weld whatever you need for whatever turbo you're running
what turbo would be ok for 300bhp on a c20let
Hahahaha, you said flange.
/Beavis
TD05 is round and 4 bolt, usually. Could be anything though without dimensions.
flange lmao
td05's are supposed to be all the rage on lets arent they??
thats what they are called aint they hehe
td05 good for 300bhp?
Yeah, easily. It's not so much they're all the rage, they're just standard on Evos and Imprezas so they're cheap, plentiful and tough as old boots, and there's 18g and 20g mods for them that will take you to around 400bhp.
Which ones better to get. The 20g?
well, it's bigger... but more laggy. There are loads of different variants depending on the year you get it off, different hotsides, different coldsides, different shafts and bearings etc
