Astra GSI Z20LEH Turbo
Results 1 to 7 of 7
Thread: Astra GSI Z20LEH Turbo
    Sep 2007
    Dunoon, Argyll
    Mk4 Astra GSI Turbo
    Alrite...i have a turbo off of an astra vxr and was wondering if i could put it on to my gsi (Z20LET) without needing a remap? I plan on getting a vxr afm and injectors at some point but my standard z20let turbo is making a funny buzzing sound when coming off the throttle so was wondering if i could put the vxr turbo straight on?
    Cheers
    Sep 2007
    Dunoon, Argyll
    Mk4 Astra GSI Turbo
    Re: Astra GSI Z20LEH Turbo
    Oct 2010
    county durham
    astra coupe turbo
    yes you can go onto courtenay sport website and they have a pdf fitting guide. you just have to back the actuator off until 5mm is showing otherwise your ecu will go into limp mode. you will need to use your z20let water feed as they are different from vxr engines.
    Sep 2009
    Bristol
    VX220 Turbo, 485 BHP.
    contrary to 'street talk', the performance between the 2 turbos is virtually identical, so no remap is required.
    Less than 300 BHP makes the baby Jesus cry, more than 450 makes him a happy passenger!
    Sep 2007
    Dunoon, Argyll
    Mk4 Astra GSI Turbo
    Cheers guys...should it be a pretty straight forward swap over then?
    Sep 2007
    Dunoon, Argyll
    Mk4 Astra GSI Turbo
    Just read it there...it says that it will not ned a remap for standard cars. Mines remaped and has a collins 31 actuator. Do i still set the actuator back 5mm then?
    Oct 2010
    county durham
    astra coupe turbo
    you should be safe enough to match the boost with the vxr unit, only reasons people change to vxr as they can make more boost than the z20let so in turn more power/torque and supposed to be stronger units the latter part i dont agree with
