Help dropped speedo gear inside f28
Results 1 to 6 of 6
Thread: Help dropped speedo gear inside f28
    Apr 2009
    coventry
    corsa + astra turbos
    Tried doin speeso cable today and the bit on the box was nackerd so removed but as doing so the inner peice about 4mm diamiter and the worm gear fell into box now
    Im just left with the large plastix
    Housing
    Will it damage box or will gears just crunch it up engine and box are coming out in november rather not have to do box now and again in 2 months
    Help
    now making stainless heatsheilds and tophat covers :) http://www.migweb.co.uk/forums/items...at-covers.html
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Re: Help dropped speedo gear inside f28
    the long plastic thing with gear on it?
    Try shaking the box upside down lol. I wouldn't try and crunch it up though.
    Apr 2009
    coventry
    Ye mate the long thin shaft with gear , cant really shake havent got
    Hydraulics lol i was hoping
    It would be sitting in the bottom
    Of box and maybe get it it via the drain hole? As there is no acess plate like there is on the f20 need help quick
    Apr 2009
    coventry
    Forogt to say i had to drive to work in it ans was ok no noises and every gear selectin ok just worried as cant afford another f28 and quaife
    Feb 2010
    North East
    Cavalier Turbo 4x4
    Quote Originally Posted by corsa-let-09 View Post
    Similar thing happened to me mate. Its still in the gearbox, no signs of damage haha
    Northeast Kent
    the worry you have is that diff crown wheel runs half submerged in the "sump" of the gearbox, so its always frapping gear oil everywhere and statistically the gear might one day follow.
    the diff housing is also shared with the gears on F28, so double jeopardy. F20/F16 the diff is in is own housing separated
