C20xe & twin 45's...
Results 1 to 23 of 23
Thread: C20xe & twin 45's...
    Aug 2011
    Surrey
    Tb'd xe corsa
    I have a c20xe (coil pack version) and have jus got twin 45 carbs, could someone pls shed some light on wat I need to do the conversion and if I can do with coil pack type engine as was under the impression I needed the distributor type...
    Cheers
    Apr 2008
    tyne and wear
    corsa c z20leh + m32
    Re: C20xe & twin 45's...
    on my old corsa i used a mk2 cav dizzy and ignition module. is there not just a blanking plate that you can remove in order to fit a dizzy or is the head different?
    Aug 2011
    Surrey
    Tb'd xe corsa
    Thread Starter
    I think there is but have seen somewhere u can use coil pack, which I'd prefer to do as better ignition, jus want someone to confirm it really...and tell me wat parts I need other than inlet and management. Cheers
  5. Remove Advertisements
    Nov 2010
    south shields
    CORSA C SRi
    if you want to run a dizzy setup you will need to change the exhaust cam for an early type. then use a dizzy, coil and ignition amp setup from a mk2 cav 1.6/1.8 (check the drive on the dizzy as it may need changing for one from a xe dizzy)
    or ring h+h ignition (0138 4261500) and tell the what your doing and they will supply evrythnk needed for ignition side of things.
    or you can use megajolt witch runs a ford edis coilpack IIRC
    when wiring the coil, there is a square black plug that joins the starting/charging loom to the c20xe loom. use the black wire that runs to your coilpack and run it to the + side of coil
    you will need a bike fuel pump or a facet type with a pressure regulator to drop pressure as carbs only need around 3/4psi
  7. #5
    Aug 2011
    Surrey
    Tb'd xe corsa
    Thread Starter
    Thanks John, that helps a little!! I think il keep it coil pack type then tbh....
  8. #6
    Nov 2010
    south shields
    CORSA C SRi
    im not to sure what you have to do with megajolt but you will need to mount a trigger wheel on the aux pully and make a bracket to hold a crank sencor
    have a read throught the how 2 bike carbs (on pg 5) thread as most of it will still help you out.
  9. #7
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Budget?
    Most distributor conversions seem to be just for RPM, which is fine if you just drive flat out all the time and don't care about getting the best out of the engine.
    There are a number of mapable electronic conversions around, which have the advantages of having exactly what 'curve' is needed for best torque/power at full throttle AND can further advance the ignition as required for part throttle use which increases torque and economy. They also tend to work with what you've already got fitted.
    An example is SBD Motorsport MBE9A4i ECU bit pricy, perhaps, as a little over 600quid with the Weber TPS, etc - however, with the cost of petrol, it may pay for itself in short order if you use the car a lot around town.
  10. #8
    Northeast Kent
    H+H uses the cavalier setup and sells it as a kit. it has vacuum feed for engine load reference
    i thought you could use a dizzy on a coil pack cam, but not the other way round. theres an offset threaded hole where the cam rotor bolts too which i believe is in the same place (dimensionally) for the offset peg on distributor.
  11. #9
    Aug 2011
    Surrey
    Tb'd xe corsa
    Thread Starter
    Cheers guys I am a bit more clued up now, gordo that is the ecu I'm thinkin of as then I won't have to convert to distributor...
  12. #10
    Nov 2010
    south shields
    CORSA C SRi
    just had a look at my coilpack cam and if you unbolt the cam rotor the drive slots are there
    h+h correct the advance curve to suite the 2ltr aswel
  13. #11
    Aug 2011
    Surrey
    Tb'd xe corsa
    Thread Starter
    Jus looked on sbd website n found most the info I need...cheers alot guys!!
  14. #12
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav v6
    The coilpack cam has a ball bearing blanking the end of the cam oilway. To fit a dizzy you would need to shorten the end of it where it goes into the cam.
  15. #13
    Aug 2011
    Surrey
    Tb'd xe corsa
    Thread Starter
    I don't want to fit a dizzy....there is no need!
  16. #14
    Sep 2008
    They're good people, have a chat to them about the setup - you'll probably get a credit for the coilpack, as you won't need it.
  17. #15
    Sep 2008
    NM, DP.
  18. #16
    Northeast Kent
    Quote Originally Posted by Corsamitch View Post
    fair enough, the only reason to use twin 45's is to reduce purchase and installation costs, thats why everyone is advising the distrubutor route, as that is also the low cost route.
    if you are gonna go out and spend 600-700 quid on an ignition only ecu, then another 300-500 having it mapped you might aswell have got throttle bodies which are superior in every other way.
  19. #17
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav v6
    My thoughts exactly
  20. #18
    Sep 2008
    Agreed, TBs would be (was) my choice, however, some people just like carb's or they may be a requirement for some types of class racing.
    With the money for selling the carb's and manifold, there wouldn't be that much difference for a 'turn key' TB installation.
  21. #19
    Aug 2011
    Surrey
    Tb'd xe corsa
    Thread Starter
    Tbh I do intend on goin throttles at a later date but I'm doin carbs as a temporary upgrade as I got almost brand new 45's off my pal for cheap! Cheap cheap! N one of my gd pals wil map it set it up etc for just a drink...
  22. #20
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav v6
    Why would you spend 600 on an ignition only setup then? Better off using a full management ecu to do ignition only in that case.
  23. #21
    Aug 2011
    Surrey
    Tb'd xe corsa
    Thread Starter
    Any u could recommend using? And does that mean I will be able to use on throttle bodies as well to save doing at a later date?
  24. #22
    Awaiting Email Confirmation
    Jun 2002
    Just bung a dizzy on to get it going, I don't know which will do ignition only then both but I'm not a mapper lol. Megasquirt might do iirc.
  25. #23
    Sep 2008
    I don't see why not, effectively you're using everything except the injector map, outputs and lambda - they may be able to be disabled in the mapping or, perhaps, a dummy resistance used if there's a problem with an open circuit..
    Have a word to the guys at some of the places that sell the the full EFI conversions and, perhaps, try contacting the manufacturers of the units.
