Zafira 1.6 16v Idles but wont rev,Fault code p1230
Results 1 to 4 of 4
Thread: Zafira 1.6 16v Idles but wont rev,Fault code p1230
    Apr 2005
    swansea
    MK4 ASTRA VAN,V
    Hi ive got a zafira on an x plate that starts and idles but wont rev.The em light is on,fault code is p1230 and when i look at the live data there's no rpm signal been picked up when the car is idling.Antone got any ideas on what to look at.
    Thanks
    That's bloody brilliant that is!
    Mig Club Member
    Apr 2011
    Sheerness, Kent.
    2003 Arden Zafira GSi
    Re: Zafira 1.6 16v Idles but wont rev,Fault code p1230
    Could be the ecu control relay? Try that.
    Apr 2005
    swansea
    MK4 ASTRA VAN,V
    Thread Starter
    ok looked at the car tonight and the code p1230 is for the main relay under the bonnet,opened cover up to reveal to purple plugs,1 with a purple relay fitted and the other with a green relay fitted with 1 pin broken off.Tried a working purple relay and it worked.Engine smoked alot but think thats down to the fact the car hasnt been running right,just idling and not reving with em light on.Smoke cleared up so service tomorrow and hopefully that will have solved it
  5. Remove Advertisements
    Mig Club Member
    Apr 2011
    Sheerness, Kent.
    I was spot on. Let me know how it goes.
  1. 09-10-2016, 15:12
  2. 06-08-2016, 04:16
  3. 05-05-2016, 14:10
