Poorly C20LET - struggle on high boost
Results 1 to 5 of 5
Thread: Poorly C20LET - struggle on high boost
    Aug 2001
    Beds
    BMW M Sport & '56 Beetle
    Hi,
    We have a slightly poorly C20Let.
    Its running Phase 3.5, K26 turbo, etc..
    It should be overboosting at 22psi, holding 18psi. But sadly its not.
    It seems to struggle on high boost only getting to 18psi and it seems to struggle/stutter/etc..
    We've changed injectors, plugs, dizzy & cap.
    Looking to change fuel filter, air filter, leads.
    I've also been suggested that the ecu may have dry joints.
    Were due to be at the Pod tomorrow so any other suggestions?
    Cheers in advance
    Rich
    if it don't scrub...... it ain't low enough!!!
    Dec 2007
    Nuneaton
    A carbed xe'd reno kangoo
    Re: Poorly C20LET - struggle on high boost
    what fuel pump are you running? i'd be leaning towards fuel what bar is your fuel set to also.
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    Mar 2002
    suffolk
    Corsa Turb n Cally Turb
    is the rotor arm the right length?
    Plug gaps?
    Leads could cause this, try wrapping them in insulation tape.
    www.wix.com/vxlgsi/zxr-750-r
    Aug 2001
    Beds
    Its a upgraded pump but im not 100% sure what one it is, fuel pressure is 4.5bar.
    Rotor arm is standard c20let from vaux so I'd presume it was all ok.
    Wrap the leads in insulating tape? All of them all the way along?
    Aug 2001
    Beds
    I'll check plug gaps aswell.
