vectra z18xe engine
hi peeps what bhp i can get from this engine if i put dbilias(copy of) inlet manifold,4 branch exhaust manifold,decat,straight thru exhaust,ported recon head,sports cams,enlarged throttle body,air feed,and ecu remap at the end.gonna start doing this next month.
was thinking of doing same thing in pug 2l gti 137 which one is better to play with?
cheers
Re: vectra z18xe engine
for z18xe engine mods, i recommend you take a look at what the chaps on corsa-c.co.uk are up to.
ok cheers will have look at it
