c16se turbo fuelling
Results 1 to 10 of 10
Thread: c16se turbo fuelling
    Mar 2011
    corsa sri c14se
    going to be turboing my c16se soon and was seeing if any one new how to get around the fueling problems?
    Dec 2009
    Llynfi Valley
    Corsa B
    Re: c16se turbo fuelling
    What sort of fuelling problems you thinking of ??
    Mar 2011
    corsa sri c14se
    over than a aftermarket ecu so the map senser can read boost is there any over way to sort out the fuel mix?
    Jun 2009
    doncaster
    83 astra 2.0 & 1.3Ti
    i'd be looking at getting the compression down first if you'v not already sorted that,
    for a start the 1.6 injectors are way too small to turbo a 1.6 and bigger 2.0 (8v type) dont fit, not sure what might fit ether but if you find out please let me know lol
    i run a 1.3 turbo that uses a 1.6 (c16se) head to lower compression to about 7.5:1
    im using the 1.6 ecu and injectors along with a 5th injector (20SEH injector) that uses the old distributor system to pulse the injector, this is on a circuit that compairs boost and mixture and turns on when it see's that its gone lean on w.o.t (not the best way but im a tight ass and it worked to get 126BHP from my 1.3 that was 70bhp just for fun) with out the 5th injector it will only cope with 2-3psi boost, with it i'v ran upto 10psi
    im going down the saab turbo Tionic 5,6 or 7 route as there programmable from a pc with free software
    so:
    lower compression (decompression plate)
    bigger injectors
    5th injector and controller (if you don't go with EDS etc)
    rising rate fuel pressure regulator
    regs
    Rich
    Mar 2011
    corsa sri c14se
    well the engine im taking out m8 is a c14se would i find it easyer to mount the the c16se head on that bottem end and turbo that?
    Jun 2009
    doncaster
    yeah that would be an easier starting point, what size turbo are you planning? i'm using a little 1.7TD turbo and it spools up quick as owt but its only rated upto 1300cc on petrol!
    Mar 2011
    corsa sri c14se
    was going to use a vectra 2.0l tdi one as all ready have one. would that be ok?
    Jun 2009
    doncaster
    should be ok, i only used the diesel one as it was £10 on ebay lol
    oil feed can be done by getting a T for the oil presure switch, m14 at male at one end and m14 female at the other, on the side was a 1/4bsp on mine so i just found a pipe that had the right ends, its normally used for remote pressure gauges
    for the return i welded a pipe into the sump lmao
    Mar 2011
    corsa sri c14se
    yer thats wat i was going to do. were do u fit the 5th injector? is it easyer to convert to carbs?
    Mar 2011
    corsa sri c14se
    would i be better off trying to get hold of a supercharger as the are runnig boost all the time so would it be easyer to sort the fueli problem?
