corsa accelerating slow
Results 1 to 23 of 23
Thread: corsa accelerating slow
    Apr 2011
    got a 1.4 corsa sport and some times it goes flat and wont accelerate very fast but if i turn the ignition off and on it goes ok for a bit can any1 help plz
    Banned
    Apr 2010
    southport
    2008 civic diesel
    Re: corsa acceleratin slow
    can you do the flash test on it? sounds like the airmass meter to me tho for a random guess.
    Apr 2011
    Thread Starter
    Re: corsa accelerating slow
    ive changed that and its still the same but thanks anyway
  5. Remove Advertisements
    Dom
    Dom is offline
    MIGWeb Moderator Dom's Avatar
    Sep 2001
    Northants
    Vectra VVT SRi
    Does the engine management light come on ?
  7. #5
    Apr 2011
    Thread Starter
    yh the light comes on
  8. #6
    Dom
    Dom is offline
    Sep 2001
    Northants
    Vectra VVT SRi
    Depending on how old the car is you may be able to read the fault codes and see why the car is having problems.
    Have a look at Topbuzz Web Site - News & articles on Vauxhall / Opel / Bedford / Holden motors @ www.topbuzz.co.uk - if you're lucky you can do the paperclip test which flashes the faults up on the dashboard.
  9. #7
    Apr 2011
    Thread Starter
    i cnt read it cause the ecu is off a 96 engine but ive got a 2000 model engine so woz jst wonderin if any1 new wot woz wrong cuz its only started doin it the last couple of months
  10. #8
    Apr 2011
    Thread Starter
    the engine management light comes on and off when the light is on it goes realy down on power but then it goes off and it runs and comes up with no codes because wen you turn the ignition on and off the fault goes so dont no what to do can any 1 help
  11. #9
    Dom
    Dom is offline
    Sep 2001
    Northants
    Vectra VVT SRi
    Whats the problem with reading the codes off ? If its a 1996 ECU then you should be able to short out the appropriate wires and do the flash test as posted above.
    If you find out why the ECU is complaining it should lead you to what you need to fix.
  12. #10
    Oct 2009
    staffordshire
    id change the map sensor had a couple in over the coming months with the same problem
  13. #11
    Awaiting Email Confirmation
    Jun 2002
    even if it is newer it'd be worth your while taking it to a garage with an obd reader, rather than randomly changing sensors.
  14. #12
    Dec 2008
    chesterfield
    BMW328Ci ACSchnitzer
    My 2000 1.2 16v corsa was doing this, I had it plugged in at my local garage and it was the EGR valve.
    I sold the 1.2 engine on here (stated needs EGR valve changing) as I put a C20XE in my corsa and he changed the EGR valve then it ran fine
  15. #13
    Dec 2010
    chelmsford
    mk3 astra
    lmaba sensor, o2 sensor, oxygen sensor, all the same thing but some people call erm diff things, would be worth changing
  16. #14
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    As it's an intermittent fault, and the car's been modified, I'd also be going over all the electrical connections and checking for damaged wiring.
  17. #15
    Oct 2009
    Stevenage
    I had this problem with my Astra last year and it was the coil pack. Bought a new one and swapped it over and I never had the fault again.
  18. #16
    Apr 2011
    Thread Starter
    hi ive changed the map sensor ,air temp sender ,coil pack and cam sensor and still got the problen so woz just wonderin if it could b the crank sensor
  19. #17
    Apr 2011
    Thread Starter
    read my car got o2 sensor so i changed it the car ran fine for a day the got the same problem again any one no wots wrong
  20. #18
    Apr 2011
    Thread Starter
    read my car again and o2 sensor has gone off and got knock sensor so just wonderin if that could drain power from my car
  21. #19
    Dom
    Dom is offline
    Sep 2001
    Northants
    Vectra VVT SRi
    Yup. Almost any fault will stuff up your engine management and it quite often goes into limp mode. You might want to check all engine earths.
  22. #20
    Apr 2011
    Thread Starter
    found the problem it was the knock sensor i put one on off a standard 1.4 corsa and it seems a little down on power is the a difference in the knock sensors
  23. #21
    Apr 2011
    Thread Starter
    any ONe help
  24. #22
    Aug 2011
    can anyone help ? i have a 1997 corsa breeze with the 1.2 8v engine and when its cold its fine and after abit the eml comes on and it wont rev it just spluters and struggles ,, help pleaseee
  25. #23
    Sep 2010
    dundee
    1.8 vectra ls
    if the eml light comes on follow the link further up this page, it tells you how to read the codes with a paperclip if you don't have access to a proper code reader
