are they a worthy addition to an xe nova?
should i fit them or sell them, and would i need to get it mapped if i fitted them?
any advice would be great
thanks, david
thanks, david
Are they the ones that feed a common plenum? ie not fully open?
Originally Posted by wayne451
there is a black cover that the air filter goes onto, is that what you mean mate?
does this pic help?
anyone?
Once fitted, you should remap the ECU
You don't have an airflow meter so I don't see how the standard ECU would cope
You will have to map if you want that it will work fine !
These throttle boddies comes withe the black plenum.
They got nice sound and are best tuning for induction engines with higher camshafts for the street.(my mind)
I got + ~40bhp with 260° Camshafts and used this car for normal day use in a x20xev
without working on the cylinderhead for about 3,5 years.
Now the head is complete worked and the engine should get new software for it , but i change the enginge to a turbo....
High level induction tuning is much expensive.
If you want a allday car with some race characteristics, put the throttle bodies in with some not too high camshafts , get the software update and have fun.
Here some pictures
Ich bin ein Berliner !
The other side?
If it has the plenum between the intake opening and the actual bodies, then it's intended to be a direct replacement fitting, with the OEM AFM supposedly working with the OEM ECU to supply the additional fuel with the knock sensor retarding if there's a problem with detonation from the better cylinder filling. I think I'd do a dyno run, at least, to ensure it wasn't running a bit lean under full power - certainly I'd be changing the fuel filter and checking the car could maintain fuel pressure under load..
I'd expect it to be a good intermediate manifoild, between stock and TBs/carb's.
For a fast road engine, I think it'd do very well!
They are supposed to run with the standard airflow meter and as such you are limited with the sorts of cams you can run on them. I'm not a fan of them tbh. Regal were claiming +30bhp on them but Total Vauxhall fitted a set years back on an X20XEV engine'd vehicle and got 15bhp on Regal's rollers and didn't have a huge amount to say about them in conclusion. For the £1200 plus fitting that was a fairly expensive day out for not a lot of gain.
I ended up selling them on guys.
