Corsa B 1.2 16v - Water pump\Cam belt
Results 1 to 12 of 12
Thread: Corsa B 1.2 16v - Water pump\Cam belt
    Nov 2009
    skegness
    vectra c
    Question Corsa B 1.2 16v - Water pump\Cam belt
    hi all my water pump has gone getting one this week this may sound stupid but havent had chance to look is thear an aux belt that its connected to or is it all cam-belt driven ....... if so am i going to have to change my belt at the same time as ive hered diffrent views on this cheers all
    MIGWeb Moderator Paul's Avatar
    Midlands
    Most days
    re: Corsa B 1.2 16v - Water pump\Cam belt
    What engine?
    Pop the bonnet. Take a look.
    Think you will find its chain driven but again please take a look.
    Nov 2009
    skegness
    vectra c
    Thread Starter
    Re: Corsa B 1.2 16v - Water pump\Cam belt
    probably is train driven havent took the cam belt cover off what i can see is about 4 pullies on a belt actually i think it is all belt driven it a z18xe
  5. Remove Advertisements
    Midlands
    Most days
    Now i'm lost.
    If you have a plastic cover, its going to be a belt.
    If doesn't have one its going to be a chain.
    A Z18XE is a 1.8 engine, not a 1.2.
  7. #5
    Midlands
    Most days
    Z12XE looks like this:-
    http://i155.photobucket.com/albums/s...00Twinport.jpg
    That a chain driven engine. No cam belt.
    The aux belt you can see will only need changing if it looks worn, although they are only about a tenner.
  8. #6
    Jan 2010
    halesowen
    corsa c with vectra 2.5
    l thought that corsa b only had the x12xe 16v and the corsa had the z range ?
  9. #7
    Nov 2009
    skegness
    vectra c
    Thread Starter
    vectra c z18xe Water pump\Cam belt
    just noticed the corsa b 1.2 sxi at the top really really dont know why thats there i got rid of that ages ago iv got a vectra c now with a z18xe sorry for the confussion something went rong somewhere
    Change what car you have in your user CP then
  10. #8
    Jun 2005
    Cracktown
    black 52' astra sxi
    it is a belt not a chain, if the water pump has broke and the timing belt has come off then it has bent valves.
    astra 2002 sxi spare parts 07521382540 wheels, cd player cdr500, lights, seats, door cards, white dials, exhaust, suspension, breaks. spoiler. wiper motors, wiper arms.
  11. #9
    Nov 2009
    skegness
    vectra c
    Thread Starter
    The belts fine it was drone having no anti freez in water pumps knackerd my question is can I re-use my cambelt also if I was to change headgasket at the same time would I need new head bolts as I've here'd they strech cheers
  12. #10
    Jun 2005
    Cracktown
    black 52' astra sxi
    did the belt slip off the water pump? if it did then the valves will be bent,
    you'll need to have the valves re-seated have the head skimmed and have new head bolts and a new gasket. i would use a new timing belt kit with a new water pump.
    then there is the oil filter, oil and antifreeze! may aswell chuck a new set of plugs in it as well.
  13. #11
    Jun 2005
    Cracktown
    black 52' astra sxi
    Quote Originally Posted by seabodSXI View Post
    it depends on what happened, does the car run at the moment?
  14. #12
    Nov 2009
    skegness
    vectra c
    Thread Starter
    yes it runs fine cam-belt is fine its just the water pump blades i think its not pumping water nothing wrong with engine or cam-belt ... can i re-use the cambelt once iv replaced the waterpump also if i change the haed gasket will i need new head bolts
