Results 1 to 9 of 9
Thread: how do you read falut codes
    Jan 2008
    dublin ireland
    CALIBRA16v turbo
    as above how do you read falut codes on a calibra turbo i know how to make it flash just dont know what it means just looks like a xmas tree to me
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Jan 2008
    dublin ireland
    CALIBRA16v turbo
    Re: how do you read falut codes
    thanks it was very helpful
    Jan 2008
    dublin ireland
    CALIBRA16v turbo
    thanks it was very helpful i flashed it and as the the web page said a healthy engine has loads of 12s and it had two others 24Vehicle speed sensor (VSS) No signal and 26Injector valve 2 High voltage any ideas how to fix this or is it a problem thanks for all the help
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    don't worry about the vss. the high voltage means open circuit. i bet if you take the lid of the injector trunking and inspect the 2 pins that connect to injector 2, 1 or both have been pushed up
    i.e they are not clipped into there correct position and hence not making contact with the injector. or the injector is funked
    Jan 2008
    dublin ireland
    CALIBRA16v turbo
    Quote Originally Posted by leesturbo View Post
    so if i check the pins if they are all right just change the number two injector .... but i thought if the injector was f33k the engine would not run right at the mo the engine is ticking over only sweet not hunting or missing.. ihave to check it tmo have spare injectors
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    it may be a intermitant fault so it may be sweet running but the ecu has logged an error there so check it out
    Jan 2008
    dublin ireland
    CALIBRA16v turbo
    thanks for all your help..... will check it out... will swap the injector to one of the others to see if it reads it again if it faluts again will swap it..
