Results 1 to 12 of 12
Thread: Vectra X20XEV Problems. Rev Limit at 4.5k???
    Aug 2008
    Barnsley
    I have an X reg Vectra SRI 140. It's done almost 130k.
    When driving it feels sluggish and not wanting to rev. It'll hit 4.5k and just feel like a rev limit. It's gone past a few times and it pulled all the way, but it's only happened about 4 times and i've had it almost 2 weeks.
    Any ideas why?
    I have changed the Air Flow Meter, cleaned the EGR as a new one is over £100. I have given it a full service. There is NO warning light on.
    Cheers, Steve.
    Sep 2004
    Nottingham M1 J26
    Cars. Loves: Dirty sluts
    Re: Vectra X20XEV Problems. Rev Limit at 4.5k???
    That sounds like a cam sensor fault or coilpack. Try the cam sensor first they always fail!
    MIGClub Member Rusty 16v's Avatar
    Jul 2002
    Pompey
    MK3 2.0 Pineapple
    Standard cam sensor fail I reckon.
    Check out my sheddy Sport!
    Oct 2008
    Moscow region, Russia
    meriva c20let
    +1
    Aug 2008
    Barnsley
    We all thinking Cam sensor then? I'll look into getting one of them 1st. Are ebay ones good enough?
    Cheers guys!
    Aug 2008
    Barnsley
    I've not had chance to buy a new sensor due to going away for 3 weeks, but the car is also stalling a lot.
    Is this also down to the cam sensor?
    MIGClub Member cmac86's Avatar
    Mar 2006
    Invercyde
    MK3LET/Vec C/VFR750
    That will be the Idle control valve causing the stalling...total nightmare on the Eco's. You can remove them and clean them but they dont last too long. Probably better off buying a new one.
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    It's going into limp home mode. Don't mess about guessing, just flash the codes out. Either short pins 5 and 6 in the diag plug and switch ign on, or hold gas and brake to the floor and switch ign on and count the ECU light flashes.
    Very likely a cam sensor playing up.
    They're there, in their room.
    Banned
    Feb 2010
    cat blocked? had it happen more than once, same symptoms wouldnt rev out fully, sluggish
    Apr 2010
    Northern Ireland
    cavalier sr1 v6
    the old xev in my cav wouldnt rev past 4500rpm and it turned out to be the cam sensor
    Aug 2008
    Barnsley
    Ok guys, thanks for you're help.
    When I get back home, i'll look into changing the Cam sensor.
    Aug 2008
    Barnsley
