Results 1 to 4 of 4
Thread: Como van rumble at certain rev range
    May 2010
    Question Como van rumble at certain rev range
    Can anyone shed any light on this. Corsa combo van 1.7 1994 diesel, engine runs fine but when I accelerate through a certain rev range (no rev counter but probably about 4-5k rpm) there is a rumble. No rumble at higher or lower revs, smooth as a nut. Don't know where from, guesses could be cv joint or gearbox/drive train? Happens the same in all gears. Thanks.
    May 2010
    Re: Como van rumble at certain rev range
    Update it is much more noticeable in the higher gears.
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    Could it be something simple like a wheel bearing? Vibrating through the car
    May 2010
    Yes, but can't understand why would this vibration happen at a certain rev range independent of the speed? Should have mentioned this, there is also alot of 'clicking' sounds when I pull off in 1st while turning hard left or right. Is this related?
