Results 1 to 13 of 13
Thread: vacume pipes on c20let which way do they go please help
    Aug 2010
    hi i have just fitted a c20let in my corsa gsi and it splutters at 4000 revs as if its got a limiter but when i play round with my vacume pipes from turbo and dumpvalve i can get it 2 run spot on with no splutter but no boost can any 1 help me and tell me which way they go plaese thanks danny.
    Dec 2002
    Essex
    Lada Riva
    Re: vacume pipes on c20let whigh way do they go please help
    You will need to post a pic realy as everyone pipes up slighly different .
    My dump valve is piped from a t-piece on the throttle body and I don't have an amal valve .
    Aug 2010
    it is just a standerd engine i took i out of the calibra but cant remember which way they went thanks
    Dec 2002
    Essex
    Lada Riva
    Do you mean the pipes from the little round thing with 3 pipes ? that's the amal valve .
    Aug 2010
    yes but my dump valve is t-piced to them as well there is 2 comes off the actuater and i from the wasegate i dont no which way they go when i swap them around the car runs fine with no sputter but no boost and when it splutters the boost is really strong then splutters at about 4000 - 6000rpm
    Aug 2010
    (1 from the wastegate lol)
    Dec 2002
    Essex
    Lada Riva
    So have you got a pipe coming from the standard re-circ ?
    Aug 2010
    yeah it has.
    Dec 2002
    Essex
    Lada Riva
    Do away with the pipe and block it off by a screw in a very short bit of pipe . When you have time take the 4 bolts off and block the re-circ so it can't open , either a 10mm thick washer or even a piece of hose pipe .
    I'd take a pipe from around the throttle body area and t-piece and join that to your dump valve
    There is a technical drawing somewhere that shows what way round the pipes go to the amal valve ... can't remember , I'll try find it .
    Dec 2002
    Essex
    Lada Riva
    Aug 2010
    thanks mate
    Dec 2002
    Essex
    Lada Riva
    Have a read on that website in the link , Untitled Document index on the left .
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Wrong sort of 'help' area!
    They're there, in their room.
