9 months ago, and just 1500miles I fitted a helix 4 paddle clutch to my corsa (210bhp xe on tbs with a quaife). the friction plate was brand new, the pressure plate wasnt.
recently ive found it hard to select gears, and when driving the other night I crunched 4th and the pedal went up towards the dash... it drives, just but is very hard to select gears, and when the clutch isnt pressed there is a rattling noise from the box as tho the friction plate is still touching the flywheel.
i cant see me killin a paddle clutch in such a short amount of time, should i assume the 2nd hand pressure plate has failed, and if it is that, do i NEED an uprated one to go with my paddle, or willl a standard one do?
Less than a year old and less than 1,500miles isn't on!!
