hi as in title im after some advise, i have a corsa c20xe which i converted my self, since ive put it in its over fueled like crazy ( estimate £10 every 2 days (25miles)) i have tried a new afm, so that isnt the problem. also when idle-ing it lumpy i think this is due to the over fueling. it pops and bangs all the time. also when im driving and i come to a stop i put my clutch in and the revs drop to under 500 rpm as if its going to cut out and then picks back up. it has often cut out when i dip the clutch but when it does i clean the throttle body out and it runs fine again for few hundred miles or so. i think the throttle body is getting coked up due to the over fueling. so all in all i need some help in sorting this over fueling problem. ANY ANSWERS?????
ive changed coolant temp sensor, its running dead lumpy and if i put my foot harshley to the floor on the gas its stutters for a second or 2 and then picks up
i will try that and see if it makes any difference, cheers
