Hi guys been having some problems with my bros mk3 1.7td gm engine. All has been fine until he went to start it yday morning and it will idle and not rev and blue smokes when it doesnt rev but stops smoking when it revs, i have messed with the vacuum pipes and it has revved cleanly and drove fine x2 but then when he stops and leave it for an hour os so it wont rev again i have checked -
1. Turbo is fine no play in shafts and if you grab the boost pipe you can feel the pressure.
2. Im unsure what the round thing is on the top of the inlet see pic
as that seems to be where the vacuum starts? if we take the boost hose off the inlet its the same as when its on so clearley its not seeing any boost? we took the pipe off last night and blew and sucked it and it revved fine and he went out in it now hes done the same this morning and it wont rev? Howver he has lately ran it on abit of veg oil, is it possibly fuel filter blocked? anyone came across this before??
this is the vacuum thing
any help appreciated!!![]()
