got a c20xe in a mk3 astra(coil pack engine)
paper clip tested the ecu and got
13 oxy sensor(dont have 1)
21 Throttle postion-high voltage
22 Throttle position-low voltage
31 crank sensor-no signal
48 battery voltage
73 Air flow sensor-low voltage
i know that the alternator is not charging fully(only 11 volts)
but the car is really holding back cutting out and just generally running rough
any1 got any ideas cheers
