Advice Needed Engine Erratic Idle and No Power. (Corsa b xe)
Results 1 to 9 of 9
Thread: Advice Needed Engine Erratic Idle and No Power. (Corsa b xe)
    Jul 2010
    corsa b redtop
    Hi guys i bought a corsa xe a few days ago since then given it a new, gearbox and clutch. i took it out and all was fine untill suddenly the revs started bouncing up and down and the power disappears (as in it wont move). Any idea's what could cause this?
    Thanks guys.
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Re: Advice Needed Engine Erratic Idle and No Power. (Corsa b xe)
    Actual engine rev's or the tachometer? Could be a crank sender.
    I'd start by checking all the connections are still sound and no wires are caught or damaged and all earths are good.
    It may be that you didn't fully tighten or connect something that has now come adrift?
    Jul 2010
    corsa b redtop
    Thread Starter
    actual engine revs. i have checked the wiring etc and it all seems to be ok. i was thinking could it be a faulty sensor and if so any idea which one?
  5. Remove Advertisements
    Jul 2010
    corsa b redtop
    Thread Starter
    bump
  7. #5
    Dec 2007
    Mossley,Manchester
    1988 16v Opel Manta
    clean you idle control valve,plenty off info on idle control valve if you do a forum search.
  8. #6
    Jul 2010
    corsa b redtop
    Thread Starter
    ok man cheers but would that cause the lack of power aswell?
  9. #7
    Dec 2007
    Mossley,Manchester
    1988 16v Opel Manta
    Quote Originally Posted by JJ24 View Post
    not sure,but mine was running bad and cleaning the idle control valve worked for me,
    plus i changed the coolant temp sensor when it was running rough another time as it was the cheapest sensor to change and that worked.
    might also be worth checking all your earths and other wiring incase you disturbed anything whilst working on your car.
  10. #8
    Dec 2007
    Mossley,Manchester
    1988 16v Opel Manta
    also had the dizzy cap and rotar arm cause problems as well....
  11. #9
    Jul 2010
    corsa b redtop
    Thread Starter
    It doesnt have a dizzy it has hall sensor and coil pack. I got told it was a calibra engine but i thought only the cav redtop was dizzyless. Im not sure lol
