Got myself a c20ne engine to put into my corsa. It has done around 100k so I'm going to give it a full service, timing belt change and also a new water pump while its out of the car. I have bought this engine because I WANT it so don't want anything like redtops mentioned. I went in my mates corsa the other day with this engine fitted and its rapid. I want to know what sort of tuning mods can be done and what sort of gains will be achieved. I have done some research but all I find for these engines is the turbo conversion as its low compression. But I would prefer to keep it n/a power.
What will bike carbs be like on this engine due to the lower compression ?? (I have the carbs already)
What will it be like if I fit the 20seh camshaft ??
What bore exhaust is best for these engines ??
I also have 20xe injectors, any point in fitting these if I don't go carbs ??
Also I heared these engines suffer with a restrictive inlet system (AFM) what can be done to get around that ??
Any other advice will be great thanks.
Liam
which to be honest I can't blame him as the xe is now getting a bit old.
