Results 1 to 9 of 9
Thread: f28 speedo help
    Aug 2007
    brighton
    C20LET 5dr corsa
    f28 speedo help
    i removed my f20 today and nocited it has a different transducer to my f28??
    my f20 had a little 3pin plug and the f28 has nothing like it...
    can i just swap them over?
    thanks
    Roll on LET power....
    May 2006
    carronshore , falkirk
    astra 2.2 supercharged
    Re: f28 speedo help
    no mate you need to open box up and swap speedo ring over to a black f20 1 , the f28 1 is blue
    Aug 2007
    brighton
    C20LET 5dr corsa
    Re: f28 speedo help
    ah right, but the f28 is mechanical..i dont want to be splitting the box
    Mar 2001
    KENT
    Astra T + Vectra Est
    Re: f28 speedo help
    no choice if you want it to read the speed correctly, else you need the turbo clocks!
    Oct 2008
    west midlands
    combo cdti
    Re: f28 speedo help
    How do you know what speedo drive you have then ? I have a f28 but i'm sure it was std so i've just got 160mph clocks to go with it, But how do i make sure it is std speedo drive, (its mechanical type)...
    When not on axle stands, I'm on boost......
    Oct 2003
    Romsey
    XE Cav, Monaro
    Re: f28 speedo help
    as he says above
    if you are going to use the 160 clocks you need the blue pinion and crownwheel fitted to the std f28 -
    undo the little keeper plate pull out the pinion from the f28 and be careful to hold the gear inside and check its blue. then check with a tiny torch down the hole and make sure the wheel is also blue. this will read right with 160 clocks, if you are running 205/50/16s that is. any other size and it still wont be right.
    Oct 2008
    west midlands
    combo cdti
    Re: f28 speedo help
    I'll br running 205/40/17 will that throw it out much ??
    Oct 2003
    Romsey
    XE Cav, Monaro
    Re: f28 speedo help
    not by much no.
    Oct 2008
    west midlands
    combo cdti
    Re: f28 speedo help
    out of intrest the bigger the wheel does it read as faster or slower than you really are going ?
