Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: Corsa sport heaters
    MIGClub Member crombievts's Avatar
    Jun 2007
    Dingwall
    type r yO
    Corsa sport heaters
    i have a 1.6 corsa sport and the heaters just suddenly stopped working. the coolant level hasnt dropped at all so its not loosing water. i took the thermostat out and put it in boiling water and it did nothing so i guess its fooked. so iv put it back together without the thermostat but the heaters are not getting hot. their not freezing, just slightly warm. is this normal with no thermostat or do i have another problem
    Feb 2007
    fife
    corsa sport + GSi
    Re: corsa sport heaters
    i might be talking sh1te here lmao but i thought the thermostat held the water back until it was hot enough, if its stuck open then maybe not geting enough time to warm up? take it when you took it out it was in the open position?
    Dec 2001
    Southampton/Reading
    The Pheonix
    Blocked heater matrix would be my guess. I here that the later Corsas are prone to it
    Apr 2009
    inverness
    how do you mean block heater matrix my mate has this problem they are warm but no where near as warm as the heaters in mine
    sex is like math: you add the bed, subtract the clothes, divide the legs and pray you dont multiply!
    Dec 2001
    Southampton/Reading
    The Pheonix
    The heater matrix is a mini radiator if you like that sits behind the dash inline with the cooling system. They are prone to bunging up with a build up of crap, gunk and general coolant system ****e. Normally due to the small core on them.
    Jun 2007
    Dingwall
    type r yO
    i think it was closed when i took it out. they do hold water back until it gets to a certain temp and since taking it out it is slightly warm. it could be a blocked matrix. 1 day it was fine and they were hot, the next day they were freezing
    Feb 2007
    fife
    corsa sport + GSi
    Can you get access to the matrix pipes? maybe worth a hose out if you can... space is tight under the bonnet. Take it a new matrix means taking dash out?
    Jun 2007
    Dingwall
    type r yO
    yes dash out job. well i think so. i really doubt it will be a blocked matrix as they just suddenly stopped working after it been left over night.
    MIGWeb User opelastra's Avatar
    Nov 2003
    Blackburn, Lancs
    Leon TDI/R200BRM
    I was just about to start a thread on this, mine has done exactly the same. Though if the engine gets over about 3200 rpm, or go around a long left hand bend () it does blow out hot air.
    2006 "55" SEAT Leon FR+ TDI 221bhp & 348lb/ft
    1999 "V" Rover 200 BRM LE #277
    Aug 2007
    brighton
    C20LET 5dr corsa
    mine does the exact same thing as well...changed the thermostat and it made no difference! all the pipes are hot but still blows out warm air not hot! and most of the time its stone cold.
    Roll on LET power....
    Jun 2007
    Dingwall
    type r yO
    hmm. 1 long left bend coming up lol. i think tomorro ill drain the water and try blowing thru the system
    Nov 2003
    Blackburn, Lancs
    Leon TDI/R200BRM
    Let us know how you get on blowing it out. What I have noticed is that just before the revs get to 3200, I can hear a "swirling" sound almost like there's an airlock on the system that's being pressured through. Very odd!
    Feb 2007
    fife
    corsa sport + GSi
    Not trying to make you guys jealous but my heaters are hot enough to melt my face, 1.6 corsa sport lmao
    Sep 2003
    South London
    Without Due Care
    Quote Originally Posted by dearing5 View Post
    Ditto! I think its the matrix tbh. Before i put my redtop in the old engine always leaked water (fu** hg) so half the time i was driving around dry i think it got clogged/corroded then .
    I dont have the will to take the dash out
    Nov 2003
    Blackburn, Lancs
    Leon TDI/R200BRM
    Quote Originally Posted by jayporn View Post
    Shove it! lmao
    Jun 2007
    Dingwall
    type r yO
    iv noticed the driver side carped it soaking but not the passanger side. i dont no where its coming from but its defo not loosing coolant
    Dec 2001
    Southampton/Reading
    The Pheonix
    Sounds to me as though the matrix is leaking then.
    Jun 2007
    Dingwall
    type r yO
    i thought that but the coolant hasnt dropped at all
    Dec 2001
    Southampton/Reading
    The Pheonix
    Your best bet is to check around the matrix and look for leaks. If thats good then check out all your drains and what not.
    Jun 2007
    Dingwall
    type r yO
    its to the back of the queue. my turbo and manifold arrived for my corsa let lol
    Nov 2003
    Blackburn, Lancs
    Leon TDI/R200BRM
    Drained and flushed my coolant through today and all is toasty again!
    Jun 2007
    Dingwall
    type r yO
    how did you flush it. i just put a jacket on
    Aug 2009
    bristol
    corsa b arden blue
    small blast with a jet wash down the pipe dont let it build pressure or it will split the matrix disconect th intake and return
    Jun 2007
    Dingwall
    type r yO
    down the pipe on the passanger side ?
  26. #25
    Aug 2009
    bristol
    corsa b arden blue
    yeh i think so i only had to do it on ka's they suffer from it never done it on mine my heaters are toastie like i said dont allow it to build pressure
