2.0 8v Conversion
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: 2.0 8v Conversion
    Dec 2009
    Llynfi Valley
    Corsa B
    2.0 8v Conversion
    Decided now i am going for a 8v conversion. Looking at getting a donor car within next two weeks. Need to know a few things.
    Can i use my f13 gearbox ??
    Can i use my driveshafts/hubs etc ??
    I will have both f13 (i think) and whatever comes with the engine so both gearbox and flywheels i will have. What box will be best on these engines for quicker acceleration etc ??
    Any help and advice will be great.
    Thanks.
    middlesex/london
    ACT z20let
    Re: 2.0 8v Conversion
    If your going to fit a 2.0 mate, go big block gearbox,shafts etc!
    Oct 2004
    C:\Earth\Unknown
    Nova
    For the 2.0 8v I would use the F16CR. That's what's normally fitted to the big block 8v. By the way is it an 20NE or 20SEH engine?
  5. Remove Advertisements
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    Quote Originally Posted by Nova_Tek View Post
    It will be the 20seh engine mate. If I can use my shafts, hubs etc that would help a lot financially
  7. #5
    Apr 2009
    inverness
    iv got an f15 on my 8v and i think its just gsi shafts unsure tho
    sex is like math: you add the bed, subtract the clothes, divide the legs and pray you dont multiply!
  8. #6
    middlesex/london
    ACT z20let
    correct me if i am wrong..........
    go f15 corsa sport gearbox
    sport shafts
    nove gsi flywheel and clutch
    and you can just get the drivers front engine mount
  9. #7
    Nov 2008
    wilmslow
    c20let corsa, volvo 360
    u need to use a 1.7 dt flywheels as that is a big block engine and use a f15 box, but it a waste off time, i had a 20seh on a f15 that i no was a gd box and it threw the diff out after 10 mile off driving (i did have a cam ported head and a 4 branch) it was quick jsut box didnt last
  10. #8
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    Well what gearbox comes with the 20seh engine because i will also have that with it. So if i use that there will be no need to change flywheel/clutch etc will there. But will i be able to still use my driveshafts and hubs ?? I will have driveshafts and hubs off the cavalier also if thats any good ??
  11. #9
    Oct 2004
    C:\Earth\Unknown
    Nova
    Like I said mate the SEH come with the F16 close ratio box.
  12. #10
    Dec 2005
    UK
    Im doing the same conversion to my corsa at the moment too with a 20seh and f16 gearbox. Im going to use the original corsa hubs and drive shafts but use mk2 cav inner cv joints to connect to the gearbox. Ive found this to be the most cost effective way for me as im on a budget too.
  13. #11
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    I have found a cavalier sri which i can get cheap, it is on a L plate. Will this be the 20seh engine ?? I dont really fancy the c20ne engine see. If this is the 20seh engine i shall do the cav mk2 inner cv's as that will be cost saving.
    Liam
  14. #12
    Oct 2009
    bershire, england
    Corsa B c20xe
    i have a whole c20ne breaking if you need bits, got cams and lightened flywheel, ecu map and others. text 07854384722
  15. #13
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    Quote Originally Posted by metterz123 View Post
    Im looking for a 20seh engine prefferebly. I cant find much info on the c20ne engines so not sure if i want one, apart from a turbo conversion i dont think there is much tunable options is there, plus its 15 bhp down on the seh before i start.
  16. #14
    Sep 2004
    Nottingham
    Cars, Loves:Whores
    Quote Originally Posted by Liam1805 View Post
    Liam
    I thought it was the earlier cavs that have the SEH. You can check the code on the ECU in the drivers footwell (GF code for SEH) or the engine number on the block!
    I reckon it'll be a C20NE though, in fact it will because on an L reg it will have a cat, which will make the engine a C-prefix (ie not a 20seh!)
    Quote Originally Posted by Benn
    When there are titties. I'm always free to help.
  17. #15
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    Quote Originally Posted by Nemesis View Post
    Thats whats been bugging me. And im unsure now weather to have it if it is the c20ne engine. Can anything be done to the ne without going turbo for worthwile gains. How would bike carbs do on these engines as the compression is lower.
  18. #16
    Oct 2009
    North Lincolnshire
    The difference between a NE and SEH is that the SEH has slightly higher comression,different cam and the ecu.This it what gives it the 15bhp more power rest of the engine is the same if the engine number starts with a C it is NOT a SEH.
  19. #17
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    Quote Originally Posted by matty h View Post
    Yess i know the differences etc. I want to know about adding bike carbs etc as the compression is lower. Looking at what type of bhp/torque levels can be achieved without going turbo or supercharging route. With 130 lb-ft torque thats a good starting point.
  20. #18
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    Will anything need to be done to the gear linkage or will that be a straight forward process too. If so then all i need is :
    Right side engine mount (custom)
    If i use f18 will need mk2 cav inners
    Anything else just list it cheers
  21. #19
    Feb 2008
    weston-super-mare
    20xe mini + 20xe corsa b
    im 99 % sure you also need gsi 22 spline driveshafts to use cav inner cv joints and your standard outer also cvs will wear quickly as there not made for the abuse
  22. #20
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    Quote Originally Posted by tinxy View Post
    Ok thanks for the heads up mate. Ill see what is cheapest when it comes to it. What about the left hand mount and rear mount can i use the ones off the ne engine and just get a drivers side one made up.
    Liam
  23. #21
    MIGWeb Lord
    Nov 2009
    Poole & Coventry
    Supercharged 2.2 Astra
    Try www.vaux-extreme.com it's the home of the 8v conversion
  24. #22
    Dec 2009
    Llynfi Valley
    Corsa B
    Thread Starter
    Thanks for the link mate
  25. #23
    Feb 2010
    wales
    c20xe corsa
    just finished mine mate with f15 box 1.7dt flywheel and 1.6 gsi clutch. standard shafts used. wiring is easy and you and stan can pop down and copy mine if u like . mike.. also standard mounts/gear linkage except the one i borrowed off you to copy on front right engine block. ps... it goes really well lots of torque
  26. #24
    Jun 2005
    Boston ,Lincolnshire
    LET Astra V6 Vec mk1astra
    good to see some old skool action and not redtop this and let that
  27. #25
    Feb 2010
    wales
    c20xe corsa
