hello all,
ive got x2 mk2 cavaliers. one is a rotten 2.0 cdi which is the donar car, and the other is a 1.6 gl.
donar engine is C20NE from 1987 E-reg Cavalier mk2 2.0 cdi.
im planning on fitting the 2.0 8v lump from the cdi to the gl, and then tuning it.
so far ive got:
1.8 8v mpi astra mk1 GTE cylinder head, gasflowed ported & polished
Kent camshaft
Piper vernier pulley
gasflowed inlet manifold & throttle body
also going to get 4 branch manifold & downpipe, and superchipped ecu.
anything else i could do to it to up the power? different injectors or something (that wont cause it to overfuel too much)
also, whats the best gearbox to use, im after something that will give good acceleration, but not wack the top end right down at the same, but im more bothered about topend speed, and it being compatable with the c20ne engine.
thanks
