Need help on c20xe
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 36
Thread: Need help on c20xe
    Jan 2005
    Malta
    Corsa 2.0, Corsa 1.7
    Need help on c20xe
    Hi guys I need help on a c20xe, I have a ticking noise, I replaced pistons, main bearings and connecting rod bearings, cleaned oil pump pick up pipe and checked relase valve, replaced oil, new water pump, new timing belt, 3 times replaced lifters( one set INA and 2 sets aftermarket) cleaned all oil paths and the ticking sound is still there, I notice it will tick when engine warms up and oil pressure starts from 75psi then is dropping to 23psi.
    Aug 2009
    cheshire
    2.1tbd astra gte 16v tigr
    Re: Need help on c20xe
    hi mate when you say you have replaced pistons and bearings was that to cure this problem of has it happened since ?
    Jan 2005
    Malta
    I replaced them to solve this problem but still is ticking.
    Aug 2009
    cheshire
    just wondering as i rebuilt a xe last year and it was doing the same as yours when it was cold it ticked then would go quiet for about 20 mins then its would knock its tits off again oil pressure would drop very low it turned out to be a big end shell oil path was blocked its on my posts on here
    Jan 2005
    Malta
    Today I removed engine from car, will continue dismantling the engine tomorrow. hope to see the problem.
    Apr 2009
    inverness
    my mates does this aswell just have the head fully rebuild all brand new parts but ticking when cold
    sex is like math: you add the bed, subtract the clothes, divide the legs and pray you dont multiply!
    Jan 2005
    Malta
    Hi guys, I began dismantling the engine today, I decided to do the engine by myself. I removed the big end bearings, cylinder head and these are some pic of the big end bearings.
    Jan 2005
    Malta
    Since I have the head apart I was thinking to check the valves and the valve guides, how do i check/ replace the valve guides?
    Jan 2005
    Malta
    tttt
    Jan 2005
    Malta
    I decieded to give it a try and try to fix but still I am looking for an LET, by any chance the oil inlet from bottom end to head is from that small hole in the middle of the bottom end,
    Aug 2004
    kings lynn
    vec gsi saloon in red
    yes that is a one way valve in the block that lets the oil into the head but stops it draining back when the engine is not running..
    Jan 2005
    Malta
    Quote Originally Posted by imacv6 View Post
    Thanks mate, can it be cleaned or removed ??
    Jan 2005
    Malta
    HI I managed to clean and check the oil way from bottom end to head, I machined some plastic stoppers so that I can close the main bearings outlets, I machined an adapter from my Nozzle Blow Gun to the oil pump inlet to block and filled the oil way with oil.
    Pics will be added tomorrow.
    Sep 2009
    Quorn,Leicestershire
    Your wheels
    If you're having problems with the one way valve, we do a replacement:
    Non return valve | Vauxhall XE (C20XE) | QED Motor Sport Ltd | Vauxhall, C20xe, Blanking, Plateo, Ri
    http://qedmotorsport.co.uk
    C20XE / X20XEV Engine Specialists
    Jan 2005
    Malta
    NO is working fine but I wanted to be sure that it is clean. Thanks
    Jan 2005
    Malta
    I am waiting for the gm head bolts, and big end bolts to arrive from GM. Any idea of a good/ reliable torque wrench
    Jan 2005
    Malta
    HI I recieved the gm main bolts, the big end bolts, bought oversize big end bearings and main bearings, gaskets . I thibk I have a problem the head bolts are different than the original longer and there is no washer
    Jan 2005
    Malta
    I replaced the head bolts to the original one,
    I need a valve spring compressor to remove the valves I think both of these are the same
    T360100 TRIDENT MULTI-VALVE SPRING COMPRESSOR on eBay (end time 15-May-10 10:19:55 BST)
    Sealey VS154 Valve Spring Compressor Multi Valve on eBay (end time 08-May-10 16:31:56 BST)
    and any idea of a good torque wrench
    Jan 2005
    Malta
    I bought a valve spring compressor it Laser its great, I removed all valves now so that I can clean every thing.
    Jan 2005
    Malta
    A little update, cleaned the head, removed cam shaft bearing since I had some of them damaged ( could not tighten them) made an insert in one of the silencer manifold.
    Pics to come
    Jan 2005
    Malta
    New Parts arrived thanks to steveboyslim
    Jan 2005
    Malta
    Some progress on my rebuilt c20xe
    this afternoon I try to do the rods and pistons, everything is clean just need to put inplace and torque
    Jan 2005
    Malta
    Hi guys some update on my rebuilt, its getting to one piece now, these are some pics.
    Pistons and connecting rods in place
    Oilpump baffle plate to be fixed tomorrow
    Z20LET oilpump and modified pickup pipe thanks to steveboyslim
    Jan 2005
    Malta
    Engine rebuilt is ready at last, I am doing my pas bracket, pics to follow.
  26. #25
    Jan 2005
    Malta
    this is the pas bracket,need some more finishing and adjustor.
