Would I be ok putting a return oil feed pipe in the front of the sump for a front mounted turbo, or would this cause problems??
I am using a steel sump and fabricated manifold, also my XE sits level and not at 7 degrees so the oil level in the sump won't be as high in the front.
Any help would be great.
