what do yous think of them? are they any good?
cheers
cheers
sex is like math: you add the bed, subtract the clothes, divide the legs and pray you dont multiply!
also what size of boost pipes yous running? 2.50 inch?
Been running an ebay intercooler for 2 years 2.5 Inch pipework. Absolutely no problems what so ever. When I had it Dyno'd the Operator made a comment on how well the intercooler was working. (very good inlet temps @ 1.BAR of boost from a KKK16)
The intercoolers are ok, just dont buy cheap hoses and clips. Pay the extra and get good silicone and Mikalor's, I learned that the hard way and ended up buying twice.
As above really. Intercooler was ace, pipes were ****ing crap. Most dangerously, they had big loose bits of wire dangling off all the welds internally.
im using the same kit as above. what car you putting 1 on
I love the Ebay cores.
i thought that was your plan lol
being reading about it, doesnt seen to hard to do, just getting it mapped will be a pain in the arse
fish is the man to ask about that. he has done a few and has a turbo 1.6 nova gsi
yeah he was right into the vauxhalls a few years back, does he still live up the back of alness?
fook all wrong with themused them for years now and put stupid amount of boodt through them . And mines a 8v turbo
JSRacing ...10.7 astra mk2 ...10.4 tigra and they are both 8v turbos both on megasquirt :)
Drag cars don't have to be pretty they just have to go fast in a straight line
might be classed as ebay purchases but alot are from actual motorsport companies lol
are you running an 8v turbo?
sorry for post above you,
screamer69 what manifold are you useing? also what management?
custon one m8used to have a cast one a few years back its far from standard engine now not to what it used to be i made 220 on standard managment years ago dont no what it its now :0 its on megasquirt and has been for the last 4 years
what modds did you have to run standard ecu? for fueling and igntion?
ne ecu had the pistons machine to lower the c/r ( i can supply the drawings if needed ) ecocrap red injectors and duel stage fuel reg amd a t34 turbo and that would see just over 11 pis before it would det never did anything to the ignition it went well enough with out doing anything i had the engine for nearly year and half then my brother had it for a year then we sold it good engine that was but we just wanted more power so we went a lot further with them and went megasquirt sold the last duel stage reg i had end of last year but if you really wanted to do it then i would bung it on megasquirt its a lot easyer and for whta your going to pay for a reg you might as well at least you can get the fueling right and not put stupid amount through it to stop it detting
end of 2008 after i blew a berand new engine apart ( dropped 2 valves in it @100mpg at pod we had a bit of fun while we built another engine and so project ****ter was born
old scrap engine with seh pistons in it and we managed to get 22 psi through that and gas then we upped it a bit more after i cracked a piston pissing around with the launch control ( it was to agressive and the fuel cut was to harsh on the pistons ) we put a set of xe pistons in it and had 22 psi through that and we wernt happy with that we put some gas through it aswell it was ok up to around 70 ish shot but we got board with that and kept upping it till it went bang and it finally gave up at 150 shot of gas so they say the 8v`s are bomb proof but not totaly![]()
shame its so far away
I do, was 70notes. Needed it to be thin for space. Inner air ways are nice and big tho.
